Broke my domoticz, plz help Topic is solved
Jeweettoch13
Domoticz version: 2026.4
Post by Jeweettoch13 »
I've tried to update my domoticz instance on my synology (7.0) trough an image update in docker. I followed the steps as mentioned to stop the container, update the image trough the Docker registry, reset the container and then start it. But now Domoticz wont come back on.
I'm sure i am missing some critical steps here. Appreciate some help :)
Jeweettoch13
Re: Broke my domoticz, plz help
Solved, topic can be closed
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
Good to know, that you have solved it meanwhile. In case you know what the solution was: It would be nice to post it here, so someone with the same problem can find it by the search funktion.
And you can mark your initial post yourself as solved by checking the checkmark icon top right.
Stop, look and listen.
Jeweettoch13
Turns out i had the port configuration wrong. What interests me is that although i'm on 2026.2, i have no option for the nightglass theme.
imautohuttraeger
I think you have to manually install the nightglass theme. At least I did it this way, but I had done that in the early beta stage already, so it was there when 2026.2 was aktiv.
I could be wrong, but 2026.2 "just" has the option of creating themes in that new way and nightglass (I love it) is "just" the first one but not (yet?) integrated in standard Domoticz installation.
Follow the instructions on GitHub:
https://github.com/galadril/Domoticz-Nightglass-Theme
Feature description:
https://galadril.github.io/Domoticz-Nightglass-Theme/
Forum post:
viewtopic.php?t=44563&hilit=Nightglass
