enever output
BartSr
- Domoticz version: V2024.7
enever output
Has someone already a script which shows electricity prices today and tomorrow in a text device?
I'm struggeling already for hours with it. User vars do show correct values.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- RonkA
- Domoticz version: 2025.1
Re: enever output
This is wat i use for the hourly price today:
My Domoticz runs in Docker on a Synology nas so i use 'http://127.17.0.2:80' to reach inside the container, adjust accordingly
I get the stats for Zonneplan from the Enever website at midnight once and these are stored under user-variable 9.
Every hour the correct hour is highlighted and a custom sensor is updated with the price of the hour.
This works 99% of the time correct but this script will become somewhat obsolete after the 1st of august because Zonneplan is moving to quater hourly prices then.
The script works good for me on a windows laptop showing chrome, don't know how it wil look on other devices..
active = true,
timer = { 'every hour' ,-- 'every minute',
'at 0:07' },
httpResponses = { 'zpPrices' }
execute = function(domoticz, trigger)
local TEXT_IDX = 436
local PRICE_SENSOR_IDX = 444 -- has to be set to correct value below near the end of the script, i was lazy!!!
local headerText = 'Zonneplan stroomprijs (€/kWh)<br>━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━<br>'
local URL = 'http://127.17.0.2:80/json.htm?type=command¶m=getuservariable&idx=9'
local function spaces(n)
return string.rep(' ', n)
-- 1. TIMER → HTTP ophalen
if trigger.isTimer then
domoticz.openURL({
url = URL,
method = 'GET',
callback = 'zpPrices'
return
-- 2. HTTP RESPONSE → verwerken
if trigger.isHTTPResponse then
if trigger.statusCode ~= 200 then
domoticz.log('HTTP fout: ' .. trigger.statusCode, domoticz.LOG_ERROR)
domoticz.devices(TEXT_IDX).updateText(headerText .. 'HTTP fout: ' .. trigger.statusCode)
return
local ok, api = pcall(domoticz.utils.fromJSON, trigger.data)
if not ok or not api or not api.result or not api.result[1] then
domoticz.log('Ongeldige Domoticz API response', domoticz.LOG_ERROR)
domoticz.devices(TEXT_IDX).updateText(headerText .. 'Ongeldige Domoticz API response')
return
local valueString = api.result[1].Value
local ok2, payload = pcall(domoticz.utils.fromJSON, valueString)
if not ok2 or not payload or not payload.data then
domoticz.log('Prijs JSON parsing mislukt', domoticz.LOG_ERROR)
domoticz.devices(TEXT_IDX).updateText(headerText .. 'Prijs JSON parsing mislukt')
return
local nowHour = os.date('%Y-%m-%dT%H') -- local nowHour = os.date('%Y-%m-%d %H')
local MAX_PRICE = 0.50
local BAR_WIDTH = 83
local output = {}
local dataLineCount = 0
local minCents = math.huge
local maxCents = -math.huge
for _, h in ipairs(payload.data) do
local prijs = tonumber(h.prijsZP)
if prijs then
local centsValue = prijs * 100
if centsValue < minCents then
minCents = centsValue
if centsValue > maxCents then
maxCents = centsValue
if minCents == math.huge then
domoticz.log('Geen geldige prijzen gevonden', domoticz.LOG_ERROR)
return
local minCentsR = domoticz.utils.round(minCents, 1)
local maxCentsR = domoticz.utils.round(maxCents, 1)
table.insert(output,
'<div style="font-family: Consolas, monospace; font-size:12px; line-height:0.9;">Laagste: '.. minCentsR.. ' ct; Hoogste: '.. maxCentsR.. ' ct')
table.insert(output, '━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━')
if prijs then
laatsteDatum = string.sub(h.datum, 1, 10)
local hour = tonumber(string.sub(h.datum, 12, 13))
local cents = string.format('%.1f', centsValue)
local centsText = cents .. ' ct'
if centsValue > 27.999 and centsValue < 29.999 then
centsText = centsText .. ' <span style="background-color:#ffc942; color:white; padding:0px 2px; border-radius:3px;">▲</span>'
if centsValue > 29.999 then
centsText = centsText .. ' <span style="background-color:#ff3029; padding:0px 2px; border-radius:3px;">▲</span>'
if centsValue == minCents then
centsText = centsText .. ' <span style="background-color:#5cb85c; color:black; padding:0px 2px; border-radius:3px;">▼</span>'
if minCents < centsValue and centsValue <= (minCents + 1.05) then
centsText = centsText .. ' <span style="background-color:#5cb85c; color:white; padding:0px 2px; border-radius:3px;">▼</span>'
local blocks = math.floor(
math.min(math.max(prijs, 0), MAX_PRICE) / MAX_PRICE * BAR_WIDTH)
local bar = string.rep('■', blocks)
local bar = '<span style="letter-spacing: -4px";>' .. bar .. '</span>'
if prijs < 0 then
bar = '<span style="color:red">' .. bar .. '</span>'
bar = '<span style="color:darkblue">' .. bar .. '</span>'
dataLineCount = dataLineCount + 1
local lineContent = string.format('%02d:00 %s %s', hour, bar, centsText)
if string.find(h.datum, nowHour, 1, true) then
lineContent =
'<span style="background-color:cyan; padding:3px 4px 2px 0px; border-radius:4px; display:inline-block;">'
.. lineContent ..
'</span>'
domoticz.devices(444).updateCustomSensor(centsValue)
local line =
(dataLineCount > 3)
and '<span style="margin-left:50px;">' .. lineContent .. '</span>'
or lineContent
table.insert(output, line)
if laatsteDatum then
local vandaag = os.date('%Y-%m-%d')
if laatsteDatum == vandaag then
table.insert(output, '<span style="font-size:12px;color:green;margin-left:50px;">Data bijgewerkt: ' .. laatsteDatum .. ' (vandaag)</span>')
table.insert(output, '<span style="font-size:12px;color:red;">LET OP: data datum is ' .. laatsteDatum .. ' (niet vandaag)</span>')
table.insert(output, '</div>')
domoticz.devices().forEach(function(device)
if device.idx == TEXT_IDX then
device.updateText(table.concat(output, '<br>'))
end)
domoticz.log('Zonneplan vandaag diagram bijgewerkt', domoticz.LOG_INFO)
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
BartSr
Re: enever output
to what refers : getuservariable&idx=9 (enever name? if so pls which?)
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- RonkA
Re: enever output
That is the uservariable IDX where in my Domoticz the string of data from Enever (Enever_Electricity_22) is stored, see Setup-More Options-User variables what your IDX is.
- gizmocuz
Re: enever output
Why a text device? Why not create a custom template page for it like the screenshot below
- RonkA
Re: enever output
Nice!! Personally i have not tried custom template's yet, but what i have running now is simple and easy to read on the dashboard by the whole family here... And i'm a fan of textdevices..(i use them a lot
BartSr
Re: enever output
Is custom template a new feature? I am not aware until now.
Re. enever plugin: is it normal behaviour thet uservar tomorrow shows now (9:33h) values of today as the tomorrow value is available kn the afternoon .
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- RonkA
Re: enever output
Yep, the tomorrow data of yesterday is not cleared at midnight, but i don't use the Enever plugin anymore since the plugin stopped functioning 2 months ago for a view Weeks..
I have this separate script to get the user variables updated, it uses 5 requests per day so it's well under the 250 request limit from the Enever account..
It's a simple script and it just works 99% like i want it to do.. (for now...)
The reason of the timing in the script to not to run exactly on midnight is because Enever site can take a view minutes over the hour updating the new data..
active = true,
timer = {
'at 00:04',
'every hour between 14:04 and 17:04'
httpResponses = {
'EneverStroomprijsVandaagCallback',
'EneverStroomprijsMorgenCallback'
logging = {
level = domoticz.LOG_INFO,
marker = 'EneverStroomprijs'
local urlVandaag = 'https://enever.nl/apiv3/stroomprijs_vandaag.php?token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx&resolution=60&price=prijsZP'
local urlMorgen = 'https://enever.nl/apiv3/stroomprijs_morgen.php?token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx&resolution=60&price=prijsZP'
local emptyText = 'Geen data'
-- TIMER EVENTS
-- Vandaag ophalen
if domoticz.time.matchesRule('at 00:04') then
domoticz.variables(10).set(emptyText) -- nieuw toegevoegd
print('variable gewist')
domoticz.log('API vandaag ophalen...', domoticz.LOG_INFO)
domoticz.openURL({
url = urlVandaag,
method = 'GET',
callback = 'EneverStroomprijsVandaagCallback'
return
-- Morgen ophalen
if domoticz.time.matchesRule('every hour between 14:05 and 17:05') then
domoticz.log('API morgen ophalen...', domoticz.LOG_INFO)
domoticz.openURL({
url = urlMorgen,
method = 'GET',
callback = 'EneverStroomprijsMorgenCallback'
return
-- HTTP RESPONSES
if not trigger.ok then
domoticz.log(
'HTTP fout: ' .. tostring(trigger.statusCode),
domoticz.LOG_ERROR
return
local json = domoticz.utils.fromJSON(trigger.data)
if not json then
domoticz.log('JSON parsing mislukt', domoticz.LOG_ERROR)
return
if json.status ~= "true" then
domoticz.log('API status is niet true', domoticz.LOG_ERROR)
return
-- VANDAAG
if trigger.callback == 'EneverStroomprijsVandaagCallback' then
domoticz.variables(9).set(trigger.data)
domoticz.log(
'Vandaag opgeslagen in variable 9',
domoticz.LOG_INFO
return
-- MORGEN
if trigger.callback == 'EneverStroomprijsMorgenCallback' then
domoticz.variables(10).set(trigger.data)
domoticz.log(
'Morgen opgeslagen in variable 10',
domoticz.LOG_INFO
return
}SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
1kke
Re: enever output
I've created a Domoticz Zonneplan plugin for personal use (provided as-is): https://github.com/frepke/Zonneplan-Domoticz-Plugin
With the included dzVents script below (which depends on the plugin and a text device), you can get this:
Personally I use the plugin for my personal dashboard:
active = true,
timer = { 'every hour' },
devices = { 332 } -- idx van het "Forecast JSON" device van de Zonneplan-plugin
logging = { level = domoticz.LOG_INFO, marker = 'ZonneplanWidget' },
-- ==================== INSTELLINGEN ====================
local SOURCE_IDX = 332 -- idx van het "Forecast JSON" device van de Zonneplan-plugin
local TARGET_IDX = 348 -- idx van het Text-device ("test")
local MAX_PRICE = 0.35 -- prijs (in euro's) die overeenkomt met een volle balk
local BAR_MAX_PX = 160 -- maximale breedte van de balk in pixels
local sourceDevice = domoticz.devices(SOURCE_IDX)
if not sourceDevice then
domoticz.log('Bron-device met idx ' .. SOURCE_IDX .. ' niet gevonden.', domoticz.LOG_ERROR)
return
local ok, payload = pcall(domoticz.utils.fromJSON, sourceDevice.sValue)
if not ok or not payload or not payload.hours then
domoticz.log('Forecast JSON parsing mislukt of veld "hours" ontbreekt.', domoticz.LOG_ERROR)
return
-- 1. Laagste / hoogste prijs bepalen
local minPrice, maxPrice = math.huge, -math.huge
for _, h in ipairs(payload.hours) do
if h.price ~= nil then
if h.price < minPrice then minPrice = h.price end
if h.price > maxPrice then maxPrice = h.price end
if minPrice == math.huge then
domoticz.log('Geen geldige prijzen gevonden in Forecast JSON.', domoticz.LOG_ERROR)
return
local minCents = domoticz.utils.round(minPrice * 100, 1)
local maxCents = domoticz.utils.round(maxPrice * 100, 1)
-- 2. Huidig lokaal uur (zelf bepaald, onafhankelijk van "is_current" in de bron-JSON,
-- zodat de highlight ook klopt als de plugin het bestand niet elk uur herschrijft)
local nowDate = os.date('%Y-%m-%d')
local nowHour = os.date('%H')
local rowsHtml = {}
local lastLocalDate = nil
-- 3. Per uur een rij opbouwen (div + inline-block spans, GEEN table!)
if h.price ~= nil and h.local_datetime then
local dateStr = string.sub(h.local_datetime, 1, 10)
local hourStr = string.sub(h.local_datetime, 12, 13)
lastLocalDate = dateStr
local cents = domoticz.utils.round(h.price * 100, 1)
local centsText = string.format('%.1f ct', cents)
-- kleur-badges op basis van prijsniveau
if cents > 27.999 and cents <= 29.999 then
' <span style="background-color:#ffc942; color:white; padding:0px 3px; border-radius:3px;">▲</span>'
elseif cents > 29.999 then
' <span style="background-color:#ff3029; color:white; padding:0px 3px; border-radius:3px;">▲</span>'
if cents == minCents or (cents > minCents and cents <= (minCents + 1.05)) then
' <span style="background-color:#5cb85c; color:white; padding:0px 3px; border-radius:3px;">▼</span>'
-- balk: breedte in pixels, percentage van MAX_PRICE
local ratio = math.min(math.max(h.price, 0), MAX_PRICE) / MAX_PRICE
local barPx = math.floor(ratio * BAR_MAX_PX)
local barColor = (h.price < 0) and '#e74c3c' or '#1a2f6b'
local barHtml =
'<span style="display:inline-block; vertical-align:middle; background-color:#e8e8ea; width:' ..
BAR_MAX_PX .. 'px; height:12px;">' ..
'<span style="display:inline-block; background-color:' .. barColor ..
'; width:' .. barPx .. 'px; height:12px;"></span>' ..
'</span>'
local timeHtml =
'<span style="display:inline-block; width:44px; vertical-align:middle;">' ..
hourStr .. ':00</span>'
local priceHtml =
'<span style="display:inline-block; margin-left:8px; vertical-align:middle;">' ..
centsText .. '</span>'
local rowHtml = timeHtml .. barHtml .. priceHtml
-- huidig uur highlighten (hele regel, geen aparte div/table-context)
if dateStr == nowDate and hourStr == nowHour then
rowHtml =
'<span style="background-color:cyan; display:inline-block; padding:1px 4px; border-radius:3px;">' ..
rowHtml .. '</span>'
table.insert(rowsHtml, rowHtml)
-- 4. Footer: laatst bijgewerkt
local footer = ''
if lastLocalDate then
if lastLocalDate >= nowDate then
footer = '<span style="font-size:12px; color:green;">Data bijgewerkt: ' ..
(payload.updated or lastLocalDate) .. '</span>'
footer = '<span style="font-size:12px; color:red;">LET OP: laatste data is van ' ..
lastLocalDate .. ' (niet vandaag)</span>'
local ICON_MARGIN_LEFT = 65 -- pas dit aan als het niet precies naast jouw device-icoon uitkomt (px)
local html =
'<div style="font-family: Consolas, monospace; font-size:12px; margin:0; margin-left:' .. ICON_MARGIN_LEFT .. 'px; padding:0; text-indent:0;">' ..
'<div style="margin:0; padding:0; text-indent:0;">Laagste: ' .. minCents .. ' ct; Hoogste: ' .. maxCents .. ' ct</div>' ..
'<div style="margin:2px 0 4px 0; padding:0; border-top:1px solid #333; width:100%;"></div>'
for _, r in ipairs(rowsHtml) do
html = html .. '<div style="margin:0; padding:0; text-indent:0; line-height:1.6;">' .. r .. '</div>'
html = html .. '<div style="margin-top:4px; padding:0; text-indent:0;">' .. footer .. '</div>' .. '</div>'
domoticz.devices(TARGET_IDX).updateText(html)
domoticz.log('Zonneplan widget bijgewerkt.', domoticz.LOG_INFO)
infoed
Re: enever output
Hi gizmocuz, "Why not create a custom template page for it like the screenshot below"
You mean the custom html page in the templates map?
With what graph engine did you create that page? Grafana? Could you please post an example HTML of yours?
- RonkA
Re: enever output
Quick remark,
Zonneplan is just 1 Dutch energy supplier, also Enever is supplying data for a lot of Dutch energy suppliers..
So not all the users of Domoticz wil this be useful if they use another supplier and certanly not useful for people living outside the Netherlands..
1kke
Re: enever output
Yes that's correct, but the Enever prices aren't always the correct ones for Zonneplan so I decided to make a plugin which shows the same prices as the Zonneplan app/website because it uses Zonneplan as source.RonkA wrote: Wednesday 08 July 2026 16:34 Quick remark,
- RonkA
Re: enever output
Ok, my remark was pointed at infoed's post, it's not about your plugin..
To your contribution to this thread i want to say that the plugin looks great on your dashboard!! and i will try to install and use it in the near future in my setup..
The text-device created is IMHO waayy to long and spacious for my liking so i wil not be using that in it's original form but maybe rewrite it sometime to keep it at 24 hours displayed with 3 hour history in the text-device..
BartSr
Re: enever output
Do you have info about it?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
1kke
Re: enever output
No worries, I wasn't feel attacked. I just clarified why I made the plugin.RonkA wrote: Thursday 09 July 2026 10:36 Ok, my remark was pointed at infoed's post, it's not about your plugin..
The text file created by the plugin with all the json content you can simply disable in the devices tap (it will st work), the other text file filed with the data from the dzVents script was a quick script I've made as an example what maybe @Bartsr can use if he want.
Tukker
- Domoticz version: 2023.2
Re: enever output
I designed a new Day-Ahead Electricity Prices plugin and Claude coded it.
You can find it @ https://github.com/Poppinkpop/domoticz- ... rts-prices
It gets prices from energy-charts.info for 10 countries/bidding zones: Netherlands, Belgium, Germany-Luxembourg, France, Austria, Denmark West, Denmark East, Norway South, Poland, Spain. Add the hardware again with a different country to track more than one at once.
Bugs bug me.
manjh
- Domoticz version: 2025.2
Re: enever output
I installed it and it is running OK, but I see an error on the log:
What does this mean?
Error: dzVents: Method updateCustomSensor is not available for device "Enever Price Sensor" (deviceType=General, deviceSubType=Text). If you believe this is not correct, please report.Hans
- Domoticz version: 2026.3
Re: enever output
That is an error from a dzvents script and not related to this plugin.manjh wrote: Sunday 12 July 2026 12:43 I installed it and it is running OK, but I see an error on the log:
What does this mean?Code: Select all
manjh
Re: enever output
Right. I installed the code from the top of this topic, that throws the error.
Hans
