sValue of Key ThemeSettings has an extreme size
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Gravityz
- Domoticz version: 2026.3
i just upgraded from 18034 to 18064
i am getting this error in the log.
i am using the default theme but also mapped the nightglass theme
2026-07-02 16:37:31.359 Error: Preferences: sValue of Key ThemeSettings has an extreme size. Please report on the forum
does anybody know if this is serious
i stopped the container and restarted it again.
no error since
weird
no error since
weird
Gravityz
Re: sValue of Key ThemeSettings has an extreme size
upgradd again and the same error. apppears.
i says please report on the forum (which i did)
- gizmocuz
You do not have this issue with the default theme. So please report this on the nightglass github issue page
Gravityz
i have this issue when nightglass is mapped but i am using the default theme.
so is this a nightglass issue?
If you do not use the nightglass theme you can remove the user variables related to the theme. It should solve the issue.
Gravityz
how can i do that
waltervl wrote: Monday 06 July 2026 10:09 If you do not use the nightglass theme you can remove the user variables related to the theme. It should solve the issue.
Go to menu Setup -> More Options > User variables, select the varable ngThemeSettings and delete it.
Gravityz
that field is empty, no varables at all
Gravityz
i am using chrome now and apparently the entry is created now.
this string holds the settings for nightglass theme and is really big.
if i delete it i weill probably loose my nightglass user settings
what is the max value for a user variable string?
{"showLastUpdate":true,"uppercaseNames":false,"iconSize":"110","fontSize":"105","liveToasts":false,"liveToastDuration":"2","deviceIconOverrides":{"6":{"iconOn":"fa-solid fa-microchip","on":"#4e9af1","off":"#555770","name":"Memory Usage","keepColor":true},"10":{"iconOn":"fa-solid fa-microchip","on":"#4e9af1","off":"#555770","name":"CPU_Usage","keepColor":true},"217":{"iconOn":"fa-solid fa-mobile-screen","on":"#4caf7d","off":"#555770","name":"Ronald-iPhone"},"218":{"iconOn":"fa-solid fa-tablet-screen-button","on":"#4caf7d","off":"#555770","name":"Linda-iPad"},"254":{"iconOn":"fa-solid fa-mobile-screen","on":"#4caf7d","off":"#555770","name":"Ryan-iPhone"},"255":{"iconOn":"fa-solid fa-mobile-screen","on":"#4caf7d","off":"#555770","name":"Linda-iPhone"},"257":{"iconOn":"fa-solid fa-wifi","on":"#4caf7d","off":"#555770","name":"WiFi Aanwezigheid"},"280":{"iconOn":"fa-solid fa-bolt","on":"#4e9af1","off":"#555770","name":"Energie"},"312":{"iconOn":"fa-solid fa-sun","on":"#b0b3c6","off":"#555770","name":"Sun Power"},"323":{"iconOn":"fa-solid fa-bolt","on":"#4e9af1","off":"#555770","name":"Energie Laag tarief"},"324":{"iconOn":"fa-solid fa-bolt","on":"#4e9af1","off":"#555770","name":"Energie Hoog tarief"},"326":{"iconOn":"fa-solid fa-clock","on":"#b0b3c6","off":"#555770","name":"Next Rainshower Leadtime"},"338":{"iconOn":"fa-solid fa-faucet","on":"#29b6f6","off":"#555770","name":"Flow","keepColor":true},"344":{"iconOn":"fa-solid fa-water","on":"#4e9af1","off":"#555770","name":"Watermeter"},"349":{"iconOn":"fa-solid fa-seedling","on":"#b0b3c6","off":"#555770","name":"CO2Slaapkamer","keepColor":true},"407":{"iconOn":"fa-solid fa-network-wired","on":"#e05555","off":"#555770","name":"WAN verbinding"},"417":{"iconOn":"fa-solid fa-network-wired","on":"#4caf7d","off":"#555770","name":"IP-Douchelamp"},"425":{"iconOn":"fa-solid fa-fan","on":"#4e9af1","off":"#555770","name":"Flair Control Mode"},"430":{"iconOn":"fa-solid fa-hand-holding-droplet","on":"#4e9af1","off":"#555770","name":"Flair (Luchtvochtigheid naar binnen)","keepColor":true},"434":{"iconOn":"fa-solid fa-hand-holding-droplet","on":"#4e9af1","off":"#555770","name":"Flair (Luchtvochtigheid naar buiten)","keepColor":true},"437":{"iconOn":"fa-solid fa-hand-holding-droplet","on":"#4e9af1","off":"#555770","name":"Vochtsensor badkamer","keepColor":true},"450":{"iconOn":"fa-solid fa-sliders","on":"#4caf7d","off":"#555770","name":"Flair Vochtsensor gevoeligheid"},"472":{"iconOn":"fa-solid fa-seedling","on":"#b0b3c6","off":"#555770","name":"Indoor Air Quality"},"475":{"iconOn":"fa-solid fa-seedling","on":"#b0b3c6","off":"#555770","name":"Lucht Kwaliteit"}}}-
Gravityz
i deleted the user variable ngTheme_settings but i still get this error when restarting the container
it stated ThemeSettings and not ngTheme_settings so it is complaining about another variable
I checked the database and under Preferences there is indeed a Nightglass string which is very large.
now the strange thing is
when i set the theme to default and check the database i would expect that under ThemeSettings all the nightglass settings are gone but they remain.
2026-08-07 14:08:57.825 Error: Preferences: sValue of Key ThemeSettings has an extreme size. Please report on the forumI checked the database and under Preferences there is indeed a Nightglass string which is very large.
