Temp device not showing in Domoticz
Dave21w
Domoticz version: Stable
Post by Dave21w »
Hi, i recently installed for a friend a Mumubiz TYGTH16A-D1RF smart switch, he has the very latests Domoticz installed and all other devices work and are detected correctly using latest Z2M with Mosquitto using Auto Discovery with LAN interface. This device is a simple mains relay output with a temperature probe. Z2M detects it correctly andin the exposes tab you can see the switch state and the probe temp, in MQTT Explorer both devices can also been seen and there state changes accordingly but Domoticz only detects the switch, no temp device appears.
I have a spare unit which i have installed on my test system which again is running the very latest of everything including the current beta of Domoticz but the result is the same. Looking at the log (below) you can see when it is first detected Domoticz finds all the option including temp calibration but never see's the actual device so no temp value widget is generated. How can i get around this ?
Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (unique_id: 0xa4c13822ffae691f_switch_zigbee2mqtt)
2026-06-29 08:06:54.839  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (Child lock) (unique_id: 0xa4c13822ffae691f_switch_child_lock_zigbee2mqtt)
2026-06-29 08:06:54.901  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (unique_id: 0xa4c13822ffae691f_temperature_zigbee2mqtt)
2026-06-29 08:06:54.902  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (unique_id: 0xa4c13822ffae691f_humidity_zigbee2mqtt)
2026-06-29 08:06:54.957  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (Temperature calibration) (unique_id: 0xa4c13822ffae691f_temperature_calibration_zigbee2mqtt)
2026-06-29 08:06:54.958  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (Humidity calibration) (unique_id: 0xa4c13822ffae691f_humidity_calibration_zigbee2mqtt)
2026-06-29 08:06:55.046  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (Temperature sensitivity) (unique_id: 0xa4c13822ffae691f_temperature_sensitivity_zigbee2mqtt)
2026-06-29 08:06:55.097  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (Humidity sensitivity) (unique_id: 0xa4c13822ffae691f_humidity_sensitivity_zigbee2mqtt)
2026-06-29 08:06:55.098  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (Manual mode) (unique_id: 0xa4c13822ffae691f_switch_manual_mode_zigbee2mqtt)
2026-06-29 08:06:55.169  Status: MQTT Auto Discovery: Discovered: 0xa4c13822ffae691f/0xa4c13822ffae691f (Auto settings) (unique_id: 0xa4c13822ffae691f_auto_settings_zigbee2mqtt)
Dave21w
Re: Temp device not showing in Domoticz
Post by Dave21w »
Can anyone help with this please
I have now found an answer but its a bit of a pain, this particular zigbee switch comes with a temp probe (not temp and humidity) it appears Domoticz won't create the widget until it sees both values as plugging in a sensor that does both makes the widget appear, I can then swap to the temp only probe and the temp value is updated but the Hum value is then present but stuck on what ever was sent last. I can use this as a work around but we need the temp only option as the probe is actually in pond water to enable a heater in winter time. Would be nice if the widget didn't have to have the stuck value present.
palnic
Domoticz version: V3.8153
Post by palnic »
I have the same issue with Mumubiz TYGTH16A-D1RF: the Z2M is reporting temperature, but Domoticz doesn't show the temp device. Also, here is another device with the same problem https://www.aliexpress.us/item/3256807 ... pt=glo2usa with only temp probe. Z2M detected it as a TS0201, but there is no temp device in Domoticz
Domoticz version: 2026.3
If you have issues with Zigbee2MQTT over Domoticz MQTT AD check the config topics, see
https://wiki.domoticz.com/MQTT_AD_Report_Problems
palnic
Post by palnic »
waltervl wrote: Thursday 16 July 2026 17:33 If you have issues with Zigbee2MQTT over Domoticz MQTT AD check the config topics, see
" issue creation is restricted in this repository"
palnic
Post by palnic »
It is fixed, please reviewhttps://github.com/domoticz/domoticz/issues/6924. Thanks to gizmocuz.
