Start and restart commands let Domoticz run immediately Topic is solved
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
I have a question of basic understanding.
I am running Domoticz (non docker) on a RasPi with Trixie.
If Domoticz is running and I execute the stop command
sudo systemctl stop domoticz.service
Domoticz is really stopping (not reacting anymore) as expected.
If I then execute the start command
sudo systemctl start domoticz.service
it is active immediately.
If Domoticz is running and I execute the restart command
sudo systemctl restart domoticz.service
it is also active immediately.
Question: Is it correct, that both start and restart lets Domoticz run immediately without a period of time for loading?
Stop, look and listen.
Domoticz version: 2026.3
Re: Start and restart commands let Domoticz run immediately
You can check the log if you dont trust the service stops....
imautohuttraeger
The stop command is not the problem. It is definitely working
But I am wondering if a starting domoticz can really be fully loaded in the same second as the start command is executed. Is it the same at your end?
However, your hint to look in the log is really straight foreward. Thanks! I will check that and revert.
Just started my Domoticz server, looking at the log I see that the webserver of Domoticz started 0.027 seconds after I started Domoticz.,...
2026-06-25 00:02:14.765  Status: Domoticz V2026.2 (build 18016)-beta (c)2012-2026 GizMoCuz
2026-06-25 00:02:14.765  Status: Build Hash: af75c37d7, Date: 2026-06-12 09:43:39
2026-06-25 00:02:14.792  Status: WebServer(HTTP) started on address: :: with port 8080
imautohuttraeger
I can confirm now, that it is indeed that fast. It starts within a fraction of a second.
As a "normal" computer user, I was skeptical, because I experience this maybe with the Windows editor, but not with highly sophisticated Programs. That's impressive for me!
