Invalid Buienradar data?
Jeweettoch13
Domoticz version: 2026.4
Post by Jeweettoch13 »
Anyone else experience a problem on the Buienradar data in domoticz?
Upon inspecting i get the following outcome:
SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
Buienradar.Weather.Models.JsonFeed
marcorupert
Re: Invalid Buienradar data?
Post by marcorupert »
2026-06-10 16:38:05.146 Error: buienradar: Invalid data received! (Check Station ID!)
Domoticz version: 2026.3
Could be related to the buienradar missing windspeed issue on some KNMI/buienradar measuring stations:
viewtopic.php?t=44645
zicht
Domoticz version: 2023.1+
Post by zicht »
Thanks Walter
same problem here ...
tried all these :
6340 Woensdrecht
6331 Tholen
6350 Gilze Rijen
6324 Stavenisse
6315 Hansweert
6323 Goes
6343 Rotterdam Geulhaven
6344 Rotterdam
6319 Westdorpe
all give "Error: buienradar: Invalid data received! (Check Station ID!)"
Arjan2019
Post by Arjan2019 »
https://data.buienradar.nl/2.0/feed/json
Buienradar got a problem the json is empty
fdemees
Domoticz version: 2024.7
Post by fdemees »
waltervl wrote: Wednesday 10 June 2026 17:16 Could be related to the buienradar missing windspeed
Hi Walter,
I don't think so.
Buienradar device returns no answer since yesterday (9 June) around 15h40.
Log entries show: Invalid data received! (Check Station ID!)
Domoticz on Rpi 3B+, ZigbeeforDomoticz, Sonoff Zigbee coordinator, several Sonoff/ESPEasy/Tasmota, IPX800, several Zigbee things, Ksenia Lares, HomeWizard batteries
Gingerpale
Domoticz version: 2026.1
Post by Gingerpale »
I can confirm, same issue here and from about the same time: June 9th, 15.45. I have tried different stationID's, Lat,Lon and 0. Nothing seems to work anymore. And https://data.buienradar.nl/2.0/feed/json returns (only):
Rpi4B,RFX433e,PiFace2, LCD, Hue bridge, Alexa (+TTS), HA-Bridge, Sonoff NSPanel, Sonoff RF (+IR) bridge, Nefit CV, Tasmota/MQTT, Enphase Solar, Smartmeter, Alarm I/F, H13726B Weather Station, CM180 Energy meter, Sonoff, KaKu, Tuya, Gledopto, AriLux,...
HansieNL
Post by HansieNL »
Looks like problem is solved.
In browser I get info, but not in Domoticz?
Blah blah blah
WouterO
Post by WouterO »
Good to know that it is not “us”, but them. That saves a lot of trouble shooting.
Next question: is Buienradar aware of this problem? I wouldn’t know how to contact them.
WouterO
Post by WouterO »
HansieNL wrote: Thursday 11 June 2026 9:59 Looks like problem is solved.
Same here: the json feed sends data again, but nothing shows up in Domoticz.
infoed
Post by infoed »
No, It's "us". That is, using https://data.buienradar.nl/2.0/feed/json returns the data. What feed is the buienradar plugin using?
WouterO
Post by WouterO »
infoed wrote: Thursday 11 June 2026 10:20 No, It's "us". That is, using https://data.buienradar.nl/2.0/feed/json returns the data. What feed is the buienradar plugin using?
Only since around 10.00 hr today, the feed started sending data again. It was them initially, but why the data isn’t appearing in Domoticz, I’ve no clue.
Kees789
Post by Kees789 »
The json data receive doesn’t contain the longitude and latitude of the weather station. Bothe values are still 0 and 0.
So with the given longitude and latitude the weather station can’t be calculated and then no data will appear in domoticz.
fdemees
Post by fdemees »
There may be another URL.
I cannot find any external script for buienradar. Indeed it is compiled and hardcoded inside domoticz.
# strings ./domoticz|grep buienradar.nl
https://gpsgadget.buienradar.nl/data/raintext/?lat=
https://gpsgadget.buienradar.nl/gadget/forecastandstation/
https://gpsgadget.buienradar.nl/gadget/ ... ndstation/ returns "Station 0 niet gevonden."
I have no clue how to pass parameters to this URL.
fdemees
Post by fdemees »
Kees789 wrote: Thursday 11 June 2026 11:04 The json data receive doesn’t contain the longitude and latitude ...
Personally, my Buienradar values are stuck since 9 June 15h40, whatever I specify my Lat and Lon coordinates in the Hardware setup , or leave the field empty as it was (until yesterday).
LarsK
Post by LarsK »
I have the same problem in Domoticz
vespino
Post by vespino »
From the looks of it, Buienradar has made changes to their feed. This is how my PHP script used to read data:
foreach($datasets->actual->stationmeasurements as $dataset)
They have changed actual to Actual and stationmeasurements to WeatherStationMeasurements.
I used to extract temperature and sunpower which have changed to Temperature and Sunpower respectively. My guess is the other values also got other names or had their capitalisation changed.
zicht
Post by zicht »
Edit : Vespino was just a bit faster (above) and found the actual changes in the feed ...
Kees789 wrote: Thursday 11 June 2026 11:04 The json data receive doesn’t contain the longitude and latitude of the weather station. Bothe values are still 0 and 0.
Correct see json part
11T21:59:00","WeatherStationMeasurements":[{"StationId":6275,"StationName":"Meetstation Arnhem"[b],"Latitude":0,"Longitude":0,[/b]"Region":null,"Timestamp":"2026-06-11T13:20:00"
But the station id is in... I hoped using the station id in the plugin would fix it. But it is not
I open https://data.buienradar.nl/2.0/feed/json in a browser en look for nearest station an use the station id (6275 for Arnhem)
But still get "Error: buienradar: Invalid data received (actual empty), or no data returned!" in the log.
Maybe some more has changed in the feed ?
vespino
Post by vespino »
Is there a way I can make the necessary changes and push an update somewhere? I'd be glad to help if I know where to look.
Doler
Post by Doler »
They changed the json. All descriptors used to use just lowercase, now they are using uppercase. So temperature has become Temperature, groundtemperature has become GroundTemperature and so on. Other things changed too like stationmeasurements has become WeatherStationMeasurements. So it's a mess.
I have my own script, changed everything and now it's working again. Till next time?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
