Version 2.2.5 released
- Bug fixed with Scenes
- Interval setting for Scene Program retrieval
Rooted Toon plugin
- madpatrick
- Domoticz version: 2026.1
Re: Rooted Toon plugin
- madpatrick
Version 2.8.0 released
- bug fixes
- Summer mode added.
We you use the setting on the Toon it will be read in Domoticz and adjust the scenes accordingly
Please read the instruction carefully how to use
- bug fixes
FunFair
@madpatrick
I've updated the plugin to version 2.8.7 trough the PyPluginStore and some data refuses to update.
http://192.168.0.35/happ_thermstat?acti ... mostatInfo
{"result":"ok", "currentTemp":"1848", "currentSetpoint":"1500", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"2", "nextProgram":"1", "nextState":"1", "nextTime":"1792557000","nextSetpoint":"1850","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
My issues:
1) currentModulationLevel (now 0, showing values earlier) stays at 100% in my domoticz device.
2) currentSetpoint (now 1500) stays at 6 degrees celcius in my domoticz device.
The devices don't seem to update properly? Any idea why?
Complete info on my devices:
574 Toon 002B0001 1 Toon temperatuur Temp LaCrosse TX3 18.4 C - - 2026-10-20 22:18:20
576 Toon 002B0004 4 Toon scenes Light/Switch Selector Switch Slapen - - 2026-10-20 21:00:50
572 Toon 002B0006 6 Toon programma informatie General Text Next program Slapen (18.5 C) at 21-10-2026 06:30:00 - - 2026-10-20 21:00:50
575 Toon 002B0002 2 Toon thermostaat setpoint Setpoint SetPoint 15.0 - - 2026-10-20 21:00:50
1767 Toon 002B000B 11 ToonRoot - Ketelmode Light/Switch Selector Switch Uit - - 2026-10-20 20:57:50
1771 Toon 002B000E 14 $ToonRoot - Zomermodus Light/Switch Switch Off - - 2026-10-20 19:30:50
573 Toon 002B0003 3 Toon programma Light/Switch Selector Switch Aan - - 2026-10-20 19:21:37
254 Toon 002B0005 5 Toon CV-ketel druk General Pressure 1.2 Bar - - 2026-10-20 19:21:37
256 Toon 002B000D 13 Toon CV-ketel setpoint Temp LaCrosse TX3 6.0 C - - 2026-10-20 19:21:37
1768 Toon 002B000C 12 Toon CV-ketel modulatie General Percentage 100% - - 2026-10-20 19:21:37
Ps. boilervalues.txt doesnt work with my Toon, i dont know if modulation uses this file. For boiler pressure and setpoint I use a shell script that reads the database.
My issues:
- madpatrick
@funfiar
I;ve created an issue on GIT for this
https://github.com/MadPatrick/domoticz_toon/issues/27
BTW you are not on the latest version. This was 2.9.2
Workaround is in v2.9.3
FunFair
I am now! It seems to work great! Thanks for the quick fix!madpatrick wrote: Friday 23 October 2026 10:17 @funfiar
I was already dusting off an old php script... but this is much better! Modulation and BoilerSetpoint are updating now.
Maybe add an option in the future to ignore the txt file?
Ps. in this version I am unable to enable debug logging in de plugin.
Pps. I am messing around with a selectorswitch triggered by a wallswitch at the front door. When I press 'away' on this button it will trigger
local toonScenes = dz.devices('Toon scenes')
toonScenes.switchSelector('Weg') but the plugin doesn't react properly and will try to switch to a value of '0'.
toonScenes.switchSelector(10) --Weg works correctly.
First time I've seen a selectorswitch act like this. Does this have something with the plugin? or a domoticz issue?
Ppps.
I've noticed when I switch manually to 'Weg' it will switch back shortly to the previous scene and then switch back to the selected scene in domoticz. Is this behaviour correct? Does this have something to do with the refresh interval?
- madpatrick
good, but please use GIT for issues.
So i can keep track of it
FunFair
Ok, I'll create git issues! Tnx
Seems I am unable to create an issue on GitHub?Create new issue
No templates available for the current repository
