I just upgraded to Domoticz version 2026.2, which looks great.
On my iphone however, the dashboard is not readable.
Does anybody know what the cause could be?
The dashboard shows correctly on my PC and I did not use dynamic dashboard.
Dashboard doesnt show right on iphone with v2026.2
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
cencen
- IMG_0977.PNG (301.73 KiB) Viewed 647 times
- gizmocuz
Re: Dashboard doesnt show right on iphone with v2026.2
And you are using the default theme? You also cleared the browser cache on your iphone?
cencen
I was not using default, but element light. After switching to default it works!
I did like element light better though.
Thanks for your help!
I encountered a similar issue with some custom interfaces after updates. Non-native themes can sometimes have display problems depending on the browser or mobile resolution. It's a bit like a site redesign; you often need to rethink mobile adaptation and ensure everything remains consistent across screens. I'm glad switching back to the default theme fixed the problem, even though Element Light is indeed more visually appealing.
Thanks for the feedback; it could help other users facing the same issue.
