check for multiple timer triggers
Gravityz
Domoticz version: 2026.3
Post by Gravityz »
i want to check for multiple timer triggers and based on the trigger time i want to execute something.
i tried several things but it does not seem to work
either the timer triggers are wrong or the check.
it did a compare with both 'at 21:00' as well as '21:00' but none of them work so i suspect the timer definition is wrong.
i want to check several times during the period of 01/05 until 09/09
can somebody help me out
timer definition
timer = {'on 01/05-09/09 at 06:00, at 12:00, at 21:00'},
check
execute = function(domoticz,event)
if event.isTimer and event.trigger == 'at 21:00'  then
        -- execute some code
Re: check for multiple timer triggers
Perhaps just log the trigger to see what you have to check against. I never used these kind of checka so no idea what the value really is. Be aware that you set a test trigger minimum 2 minutes away to be sure the trigger is registered.
if event.isTimer  then
       domoticz.log('trigger: ' .. event.trigger)
Gravityz
Post by Gravityz »
i discovered the following
Works
timer = {'on 01/05-09/09 at 07:00'},
does not work
timer = {'on 01/05-09/09 at 07:00, at 08:00'},
works
timer = {'on 01/05-09/09 at 07:00','on 01/05-09/09 at 13:00', 'on 01/05-09/09 at 21:30'},
so it seems you can do a timer with date and time but if you have multiple times you need to add the date part to every time.
also the event.trigger also includes the date part and will be 'on 01/05-09/09 at 21:30'
so for now working but i would have thought 1 date with multiple times would be more readable/logical
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
if (item.isTimer) then ... - working for me
Gravityz
Post by Gravityz »
that is not the problem.
the problem isa based on different timers execute different code
habahabahaba wrote: Thursday 28 May 2026 11:43 execute = function(domoticz, item)
habahabahaba
oh..
So try
if domoticz.time.matchesRule('on 01/05-09/09 at 06:50-07:05') then ...
Or did I misunderstand you again?
Gravityz
Post by Gravityz »
that will probably work but i want mutliple specific times, not a timeframe
so using your example i want
if domoticz.time.matchesRule('on 01/05-09/09 at 06:50, at 07:05') then ...
this does not seem to work
i can only make it work if i add the dateframe to every time
maybe this is by design
habahabahaba
'01/05-09/09 at 07:00 or at 08:00 or at 09:00'
as a variant
Gravityz
Post by Gravityz »
thanks, will test
habahabahaba wrote: Thursday 28 May 2026 18:23 '01/05-09/09 at 07:00 or at 08:00 or at 09:00'
as a variant
So you have 2 issues:
1. Getting multiple timer triggers working in the on section. But you are getting there I read above....
2. A check which timer trigger is triggered. Did you log the timer event.trigger already?
Gravityz
Post by Gravityz »
tried it but that example does not work either
this works
the trigger logged is
this works
at 07:00
the other examples doe not work and nothing is logged.
so for now i am good to go
