Alarm Panel improvements
pfloryann
Domoticz version: 2026.3
Post by pfloryann »
I have a suggestion for expanding the functionality of the alarm panel:
- be able to add the sensors you want to use in the alarm system for each mode (Away, night) and be able to set personalized notifications for the alarm without having to create different events.
-exit delay (When arming the alarm, within this time period the sensors will not trigger the alarm yet)
-entry delay(Delay time until the alarm is triggered after one of the sensors is activated)
- dedicated widget for the alarm system.
I tested https://github.com/nielsfaber/alarmo and I think something similar in domoticz would be helpful.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Re: Alarm Panel improvements
Did you see this plugin https://github.com/Beastie971/Domoticz-Alarm
I think it would need some changes as the API calls that are used are outdated but it could work and seems to be just what you described.
That link seemd to be a fork of the original.
I made another fork and fixed the images. I also fixed the plugin So I hope it works (did not test it myself)
https://github.com/waltervl/Domoticz-Alarm
