Unable to install. Server returns error 403
hanskl
Post by hanskl »
Cannot install easy way on raspberry Pi due to 403 returned by https://install.domoticz.com
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
DomoArie
Domoticz version: 3.5877
Re: Unable to install. Server returns error 403
Post by DomoArie »
I have the same error today :-( is there a different way to install Domoticz on my clean Raspberry 3B?
Domoticz version: 2026.3
Alternative is the docker way, or wait until the install location is repaired.
You can also download the correct image from download.domoticz.com and untar it
gizmocuz
Post by gizmocuz »
Thanks for reporting. My bad... new install file was named incorrectly and could not be found.
But yes, best to use docker compose and it does not depend on your system used.
DomoArie
Post by DomoArie »
Hi Gizmo
Thanks for fixing!
