RFX Meter / Uint32_t overflow Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
qqlapraline
Post by qqlapraline »
Hello everyone,
I've been using Domoticz for the past ... 13 years at least now.
My setup is somehow specific because I've been using numerous MySensors devices.
One of these devices is sending the actual usage of wooden pellet for my Mom's stove.
It is base on the V_VOLUME device for the MySensors family that is relying on .. RFXMeter devices on demotics.
I've been using 2025.1 (build 16598) for a while now because it took me some time to upgrade to Trixie on my Raspberry PI.
Once I've done the migration (to the lastest beta version), my famous V_VOLUME device had been having some trouble.
The updating value was: 3439258 but after a couple of minutes, Domoticz gave me a strange error:
Error: GetJSonDevices: exception occurred: 'stoll' (3048/Conso Pellet Moteur)
I've been digging in to see what could be the error. After a while, I realized that the updated value was transformed to: 18446744072853842432
Which is basically: 2^64-855709184 ... and -855709184 is the int32 version of 3439258112 (the transformed float version of 3439258*1000.0f).
So, in a nuttshell, it comes from a bady typed conversion.
I've created a small fix on my setup. To do so, I've change the
decode-RFXMeter
function in
mainworker.cpp
I've replaced this line:
unsigned long counter = (pResponse->RFXMETER.count1 << 24) + (pResponse->RFXMETER.count2 << 16) + (pResponse->RFXMETER.count3 << 8) + pResponse->RFXMETER.count4;
by this line:
uint32_t counter = (static_cast<uint32_t>(pResponse->RFXMETER.count1) << 24) + (static_cast<uint32_t>(pResponse->RFXMETER.count2) << 16) + (static_cast<uint32_t>(pResponse->RFXMETER.count3) << 8) + static_cast<uint32_t>(pResponse->RFXMETER.count4);
And... it works for me !
I've looked back to the history of code and I really don't understand what could have changed. May be it's a matter of compilation on my raspberry pi ... any hint ?
Regards,
Qq.
3 Raspberry PI (Raspbian + Rfxcom, teleinfo or mysensors gateway)
Bunch of OS THGR810n (5)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Bunch of DIO plugs (3)
Teleinfo
Many Mysensors devices (Temp, Hygro, ...)
gizmocuz
Re: RFX Meter / Uint32_t overflow
Post by gizmocuz »
Thank you for reporting.
The patch is implemented in beta 17965
qqlapraline
Tested and validated on my side !
Thanks, Gizmo.
Qq.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
