Plugin : HP iLo monitor
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I've created a new plugin to get the info and health status of a HP server with iLo
You can find the plugin over here : https://github.com/MadPatrick/domoticz_HP_ilo
Enjoy and feedback is welcome
screenshot 1.png (47.31 KiB) Viewed 1492 times
madpatrick
Re: New Plugin : HP iLo monitor
PosaDka wrote: Monday 18 May 2026 9:50 Nice work, iLO monitoring in Domoticz is something a lot of people have been wanting. Will give it a try and report back. Does it support iLO 4 and 5 or just one of them?
Good to hear !!
It should work with iLO 4, 5 & 6
Tested it with ilO 6 and 4, but 4 has less functionality
You can install the plugin multiple times if you have more servers
Please let me know it you have any other requirements of bugs
gizmocuz
Post by gizmocuz »
That is true. We are all running on a HP server these days :roll:
madpatrick
Re: Plugin : HP iLo monitor
I updated the Domoticz HP iLO plugin with several new Redfish/HPE management features.
Changes:
Removed the old direct Fan Speed Control device, because the individual fan Redfish resources are read-only on my iLO.
Replaced it with Minimum Fan Speed, which writes the supported HPE OEM Redfish field:
Oem/Hpe/FanPercentMinimum
Added Thermal Configuration as a selector menu with:Optimal Cooling
- Enhanced CPU Cooling
- Increased Cooling
- Maximum Cooling
- Smooth Cooling
Thermal Configuration writes:
Oem/Hpe/ThermalConfiguration
After changing Thermal Configuration, the plugin skips the immediate refresh because iLO may restart or temporarily stop responding.
Added Power Regulator as a selector menu with:
- Dynamic Power Savings Mode
- Static Low Power Mode
- Static High Performance Mode
- OS Control Mode
Power Regulator is handled through BIOS Redfish settings using: Attributes.PowerRegulator
Reused unit 4 as SSD Lifetime, showing SSD remaining lifetime in percent when Redfish exposes the value.
Added migration logic so old devices are cleaned up or recreated automatically:
- old unit 4 Fan Speed becomes SSD Lifetime
- old direct fan speed control is removed
Updated the README with the new devices, Redfish fields, and notes about iLO restart behavior.
Added the following devices:
- Unit 4: SSD Lifetime
- Unit 12: Minimum Fan Speed
- Unit 13: Thermal Configuration
- Unit 14: Power Regulator
