Do unused devices impact the performance of domoticz? Topic is solved
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
Do unused devices impact the performance of domoticz, or are they simply "sleeping" as long as they are not changed to be used devices? Of cause they increase the number of devices in the database, but are they also triggering any activity in the background? I am asking, because in sometimes, I don't want to delete them in case I might need them later.
Stop, look and listen.
gizmocuz
Re: Do unused devices impact the performance of domoticz?
Post by gizmocuz »
That depends on how you setup your system.
Have a look at Settings->Log
If you disable 'Log unused sensors' they won't cause any database activity
Also when you enable 'Only add newly received values to the Log', will decrease database activity
If you set a device to not used, it will not cause any cpu issues if that is your question.
(but can use database size if you keep 'log unused sensors' enabled
If you do not see any differences, just leave the settings as they are.
When a device is not set as 'used', it will not show up on various places (where devices need to be selected)
imautohuttraeger
Thank you very much for this detailed explanation.
