Solaredge API problem
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Bjornen
- Domoticz version: 2025.2
Re: Solaredge API problem
Hi!
Ok so I did som scripting/research.
The funny thing is that the first request /sites/list/.. etc gets a HTTP 403 Forbidden.
But since I have the parameters needed(siteid, account etc) I continued with the following command/requests:
details
inventory
equipment (here I can sometimes get a "Data after json = {'data': {'count': 0, 'telemetries': []}} ", but ok, it is not 403 forbidden.
and they all work fine..........?!?!?
So what kind of control is on Solaredges side?
Will continue to look into what you said above and try.
details
inventory
JaapB
Using this line: https://monitoringapi.solaredge.com/sit ... y=<API-key> I do get a direct report, using it without the site-id a get a "acces denied"Bjornen wrote: Thursday 12 March 2026 11:54 Hi!
details
inventory
Edit 15:00: Much to my surprise I noticed that the solaredge now is reporting again and the monitoring link without te ID now shows all information. Somehow something did change over at solaredge.
Bjornen
Hi!
Yes. After Gizmocuz instructions I did log into monitoring.solaredge.com and accepted all popups. Also got a popup in the app(suddenly) and after that the Domoticz plugin works like before.
Many thanks!!!!
Bjornen
Many thanks!!!!
Bjornen
BartSr
- Domoticz version: V2024.7
Hi! Gizmocus pointed me to this topic as my issue as posted on Github is considered not to be an issue.
Until early december last year I got data by the Solaredge API as shown hereunder. Can anyone inform me how to get these devices alive again? I already got a new API# from my installer.
Or did solaredge drop this data from the API?
Thanks for your help.
Ps I just noted I started this topic months ago
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
jannl
- Domoticz version: 2026.1.x
No idea, works here like a charm since 2015 or so.
Do you have a new router? Does the inverter have a new IP? Switched to docker (didn't have impact for me)?
Something else changed?
BartSr
Do I understand that the ' devices in red ' are up and running at your's?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
jannl
Yes, no problem
BartSr
What inverter type do you use?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Just to inform:
Finally my ongoing problem with incomplete data derived using API has been solved.
It seems that due to the fact that my supplier switched from SolarEdge to Enphase as main brand they were no longer able to provide valid API key.
After consulting SolarEdge directly they provided me with a new key. New key 'unlocked' all devices as in use before.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
