Hallo allen,
Mijn naam is Harrie.
Ben al jaren gebruiker van Domoticz.
Heb een vraag maar kan die niet verwoorden in de Engelse taal.
Mag ik vragen ook in het Nederlands stellen?
Het betreft een energie systeem met een niet gangbare accu die met CT klemmen wordt uitgelezen en die alleen de warmtepompen voorziet van energie.
Hoor graag van jullie.
Hallo ik ben nieuw hier, even voorstellen
- McTucker
- Domoticz version: 2024
jannl
- Domoticz version: 2026.1.x
Re: Hallo ik ben nieuw hier, even voorstellen
Probeer google translate.
Try google translate.
- McTucker
A few weeks ago, I received my Ecoflow Delta 3 max Pro with an extra battery, totaling 4 kWh. I use this battery in my camper.
But when I am at home, I use this battery to power my heat pumps (air conditioners).
The battery is connected to the grid via a Kaku switch.
When the battery is connected to the grid, it is charged, and the heat pumps are supplied with energy via the grid.
When the sun sets, the battery is disconnected from the grid. The battery then powers the heat pumps.
This all works properly. I can read and control everything in Domoticz without any problems.
I love my Raspberry Pi and Domoticz
But now my question: How do I logically add such a system to Domoticz?
The Energy Dashboard now is not showing any logic information.
[how to insert an image?]
![Image]()
jannl
I think the image has to be on a place the forum can reach on the internet.
In the Energy Dashboard you can add items to be displayedm is that your question?
- madpatrick
You can add images as follow
- McTucker
As you can see in the picture, device labeled "1" is my Ecoflow Delta 3 Max Plus. It is not specific a home battery, but mostly used in a RV.
Attached to the outlet of this battery is one Arco unit (device 2a and 2b), to warm en cool the groundfloor of my house.
Note, that the battery can't return energy to the grid.
Are there more people with this setup?
- domoticz1.jpg (148.33 KiB) Viewed 25125 times
