NUT/UPS problem in bookworm on docker
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
jannl
Domoticz version: 2026.1.x
Post by jannl »
Not sure if this is the right place for this question. Not even sure if it is Domoticz related.
Today I set my new pi 5 with bookworm live, most worked flawlessly with the latest docker containers.
However, NUT for the UPS connection on my Synology is not working. I always get access denied, I rellay tried a lot (DIfferent AI´ś), but no luck so far.
upsc from the host works fine, just not from within the comtainer.
I hope someone has a clue.
jannl
Re: NUT/UPS problem in bookworm on docker
Post by jannl »
Solved, different use of iptables (nftables) on docker bookworm. A lot of searching, going back to legacy iptables and adding e firewall rule for de NUT port did te trick.
