Somfy plugin is almost every 15 minutes communicating
Rik60
Domoticz version: 2026.3
Post by Rik60 »
The Somfy plugin is almost every 15 minutes communicating with the somfy box. Only during day-mode while there are no device actions. There are no errors, the log file can grow very big if not monitored. Is it nessesary to communicate every 15 minutes and log this?
somfy.log
(36.63 KiB) Downloaded 113 times
madpatrick
Domoticz version: 2026.1
Re: Somfy plugin is almost every 15 minutes communicating
Post by madpatrick »
Have you checked the readme ?
You can setup your own interval timing
Day/Night polling
Separate intervals for day and night, configurable via config.txt (DAY_INTERVAL / NIGHT_INTERVAL).
Temporary fast polling after commands for faster status updates, configurable via config.txt (TEMP_DELAY / TEMP_TIME).
I've made version 5.3.1 without the somfy.log
No need any more for this
Rik60
Post by Rik60 »
I have checked the readme. I think it's not a config setting. But thanks for the update for the logging setting
Rik60
Post by Rik60 »
Thanks for the update, indeed there is no somfy logging anymore. But what is changed? Just the version number? I am asking because i am trying to understand the changes, learning Python...
madpatrick
You can see all chanhed in the code on GIT easlily
https://github.com/MadPatrick/domoticz_ ... ts/master/
And click on the commit
2026-04-29 10_51_17-.png (71.35 KiB) Viewed 24738 times
Rik60
Post by Rik60 »
thanks, now it's clear to me :D, but don't you have to remove those lines in the other files?
