Multi-threaded plugins problem Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
mgugu
Post by mgugu »
Pi2/Trixie - Domoticz: latest beta
I tested this multi-threaded plugin example :https://github.com/domoticz/domoticz/bl ... hreaded.py
Encountered issues:
- Domoticz hangs undefinitely when I click on update
2026-04-25 10_47_11-Domoticz.jpg (129.03 KiB) Viewed 41917 times
- Restarting domoticz service is very long
Other multithreaded plugins I tested have same kind of issues.
Are there some restrictions in using multi-threaded plugins ?
jvdz
Domoticz version: 4.107
Re: Multi-threaded plugins problem
Post by jvdz »
Do you get any messages in the log when you test as the OnStop() function should show you whether it is waiting for threads to finish?
mgugu
Post by mgugu »
Yes, on another multi-threaded plugin (Domoticz universal GPIO) I get following messages after service restart or hardware update:
2026-04-25 16:14:58.240  GPIO: GPIO event_loop exited
2026-04-25 16:14:58.242  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:14:59.243  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:00.244  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:01.244  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:02.245  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:03.245  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:04.246  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:05.247  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:06.247  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:07.248  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:08.248  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:08.249  Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:08.249  Error: GPIO: Abandoning wait for Plugin thread shutdown, hang or crash may result.
And the still running thread is Mainthread
jvdz
Post by jvdz »
The example plugin you linked does tell the thread to close by supplying a None into the messagequeue: self.messageQueue.put(None), so the thread knowns it needs to stop:
                Message = self.messageQueue.get(block=True)
                if Message is None:
                    Domoticz.Debug("Exiting message handler")
                    self.messageQueue.task_done()
                    break
Have you done something similar?
Rik60
Domoticz version: 2026.3
Post by Rik60 »
mgugu wrote: Saturday 25 April 2026 16:21 Yes, on another multi-threaded plugin (Domoticz universal GPIO) I get following messages after service restart or hardware update:
Can you check the plugin code:
                if self.request.wait_edge_events(5):
and change the 5 into 0.2
copilot thinks that this is the problem
mgugu
Post by mgugu »
@jvdz, here is the multi-threaded GPIO plugin provided by Rik60, it provides error messages at restart while Multi-threaded Plugin example hangs
@Rik60, changing self.request.wait_edge_events(5) to (0.2) does not change anything.
I submitted the problem to Anthropic AI (also to improve inputs management) and he told me that the plugin is properly coded and the problem comes likely from domoticz mainthread management.
Domoticz-Universal-GPIO.zip
(2.9 KiB) Downloaded 97 times
Rik60
Post by Rik60 »
Perhaps it isn't the this plugin as you wrote. But the change worked for me. Btw, i have seen this error also when other plugin is stopping. Zigbee 4 Domoticz is also showing this error when Domoticz is restarting but i didn't pay attention to it.
gizmocuz
Post by gizmocuz »
@Rik60, yes Zigbee4domoticz has know issues, and are solved when using a new python version, but that is not officially supported
gizmocuz
Post by gizmocuz »
Should be solved when using the latest docker compose beta image (upgraded to python 3.13)
