I get everyday on the same time thread seems to have ended unexpectedly
Arjan2019
Post by Arjan2019 »
2026-04-22 23:01:37.567  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:03:15.665  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:03:29.680  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:03:43.697  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:03:57.713  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:04:11.730  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:04:25.745  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:04:39.764  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:04:53.779  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
2026-04-22 23:05:08.517  Error: Zonne Energie hardware (20) thread seems to have ended unexpectedly
And sometimes Domoticz completely crash at this time.
This hardware is from enphase
Most script are turn off at this time with
		timer = { 'at 00:02-23:00',
            'at 23:06-23:59'}
But the error is still there.
I had this problem when Domoticz was installed direct on the PI-OS but now it's installed in docker and I have the same problem.
Any know how I can solve this?
gizmocuz
Re: I get everyday on the same time thread seems to have ended unexpectedly
Post by gizmocuz »
@Arjan2019,
Is this with the native Domoticz Enphase implementation?
And what do you mean by 'Most scripts are turn off at this time' ?
You should not turn off hardware via scripts, why would you do this?
In case of Enphase, we already only poll between sunrise and sunset (-/+ 60 minutes)
Arjan2019
Post by Arjan2019 »
This is with the native enphase addon.
I don't turn hardware of but my scripts are not running at that time. Just to be sure if that is not causing the problem
gizmocuz
Post by gizmocuz »
I also assume Domoticz is the ONLY one communicating with Enphase? There may be only one connection.
I am using the native Enphase hardware myself for years, and know it is working correctly
Arjan2019
Post by Arjan2019 »
I had two pulling HA and Domoticz
No error all day with it.
But I did turn off Home assistant at 22:00 to check if this solve it but it didn't.
Anything I can try?
