You could also leave it in Domoticz and use the MQTT Pusher to push out the values and use this with another application.
Yes current is simply calculated (P = U * I)
I see no reason to install another application just to get the values on MQTT, another single point of failure
P1 Meter via DSMR4MQTT
- gizmocuz
Re: P1 Meter via DSMR4MQTT
