yesterday's sum for is incorrect Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
HansR
- Domoticz version: 4.10705
Version: v2026.1
Platform: RAspberry Pi 3B+
hardware: P1 Smart meter USB
Description: In the log for the gas the sum of yesterday is what it should be. See chart below: 13 april as example, chart is of 14 april 7h15. 13 april seems to show the value of the 12th.
Domoticz: v2026.1
System: Raspberry Pi 3B+
OS: Raspbian (Linux 6.12.47-1+rpt1 (2025-09-16))
- gizmocuz
Re: yesterday's sum for is incorrect
What happens when you press report and click on todays month
HansR
There must be days of zero gas. So the first chart does not chart the report numbers which seem correct.
Domoticz: v2026.1
- Domoticz version: 2026.3
It looks like spike detection (introduced in 2026.1) has been activated on this graph?
There is now a function in the graph section that detects 0 values and thinks the meter is incorrect and that the value with data is a total of the last days with 0 and flatten that value out over the last days with 0.
HansR
I am lost.waltervl wrote: Wednesday 15 April 2026 17:21 It looks like spike detection (introduced in 2026.1) has been activated on this graph?
What do I need to do to get a correct chart?
And btw: I regard this as a bug: you can't introduce something and simply show a wrong chart.
Domoticz: v2026.1
You cannot get a correct chart at the moment.HansR wrote: Thursday 16 April 2026 9:16I am lost.waltervl wrote: Wednesday 15 April 2026 17:21 It looks like spike detection (introduced in 2026.1) has been activated on this graph?
And I agree this implementation has some side effects that the implementer did not foresee...
Perhaps someone can create a setting switch that switches this new feature on and off?
HansR
Brilliant
Domoticz: v2026.1
- gizmocuz
Create a Github issue and mention this forum thread.
A setting seems indeed be the best option. The idea was good, but not when there are valid 0 days, or the algorithm needs to be better.
I assume you are already on the latest beta version and see this behavior? If not, it could already been solved
- imautohuttraeger
- Domoticz version: latest
Word. For example, my small solar power plant can have even several zero days, when there is thick snow on top of the panels. There is even no standby current of the micro-inverter from the grid, as it switches off as long as there is no or not enough power from the solar panels.gizmocuz wrote: Friday 17 April 2026 16:57 The idea was good, but not when there are valid 0 days, or the algorithm needs to be better.
Stop, look and listen.
HansR
Indeed, the current version on the beta channel (v2026.1 (build 17748)) has the problem solved. Thanks.gizmocuz wrote: Friday 17 April 2026 16:57 I assume you are already on the latest beta version and see this behavior? If not, it could already been solved
Domoticz: v2026.1
