avoid divide by zero  [Solved]
Gravityz
Domoticz version: 2026.3
Post by Gravityz »
is there an easy wat to avoid divide by zero?
i am substracting 2 temp values and divide those by another substracion value.
that value can be +, - or even zero
is there an easy way to avoid divide by zero or can this only be done by first doing an if then check before i divide by zero?
gizmocuz
Re: avoid divide by zero
Post by gizmocuz »
Yes, first check if "another substracion value" is not zero, if it is zero, do not divide
Gravityz
Re: avoid divide by zero  [Solved]
Post by Gravityz »
thanks. thought there might be an easy fix but this will work
