Fahrenheit to Celcius (or C to F) conversion
palnic
Domoticz version: V3.8153
Post by palnic »
I have five Tuya TS601 thermostat. They are measure temperature in Celsius. In Domoticz settings I set Temperature display in Fahrenheit. Temperature in Fahrenheit displays as a decimal, more sense to display it as an integer. When I adjust set point, I have to enter temperature in Celsius, or I am getting error
gizmocuz
Re: Fahrenheit to Celcius (or C to F) conversion
Post by gizmocuz »
When you press 'Edit' on the Setpoint, what is specified for the min/max range? You need to change this to Fahrenheit as well.
palnic
Post by palnic »
The min and max values come fromhttps://www.zigbee2mqtt.io/devices/TS06 ... ostat.html and I can't change to Fahrenheit
