Using docker with latest image of domoticz: v2026.1 (build 17652).
Output of sqlite3 /opt/domoticz/config/domoticz.db "select * from hardware where id=3" is:
3|Zonnepanelen2|1|108|7|envoy|443|443|<email address>|<password>||30|0|0|0|0|0|0||
and output of sqlite3 /opt/config/config/domoticz.db "select * from uservariables" is:
1|EnphaseToken_3|2|<enphase token>|2026-03-30 18:33:28
2|EnphaseToken_3_ex|2||2026-03-30 16:18:11
I have a bash script using these values for <email address>,<password> and <enphase token> in a curl command to get measurement values, which works. The URL in the curl command uses https://envoy/... The defined port for the hardware device is 443 as can be seen above.
Still I get in the log: 2026-04-06 19:15:43.370 Error: Zonnepanelen2: Error getting http data! (info)
The envoy uses firmware type 8.
How to configure Enphase envoy device
freekdk
- Domoticz version: V2025.1
Re: How to configure Enphase envoy device (solved)
I found the solution. The problem is with the use of the name envoy, which obviously needs to be translated into an IP-address. I did have such a definition in the host, but it needs to be defined in the /etc/hosts file in the docker image if you want to use names.
The real solution is obviously to use IP addresses.
- Domoticz version: 2026.3
Good you found it yourself as this was almost impossible to advise without knowing a lot of details of your environment....
