Webgui beta update on Ubuntu 24.04 LTS fails Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Domoticz version: 2026.3
I have a test system with Ubuntu 24.04 LTS on X86_64 architecture and the last week it fails to update over webgui (probably after reverting to SysV service method)
A restart of the service over Command line gets it working again.
Also a updatebeta over command line goes fine. It is juist the update over webhui.
The webgui update succeeds until the scripts wants to start Domoticz again.
Running "sudo service domoticz status" ends with:
 sudo[799970]: pam_unix(sudo:session): session closed for user root
I currently have no domoticz hardware gateways, no scripts running so it is a completely silent environment.
There is already a currently closed github issue because I thought it was solved but now I still have this issue.
https://github.com/domoticz/domoticz/issues/6640
Anyone else has this issue?
Rik60
Re: Webgui beta update on Ubuntu 24.04 LTS fails
Post by Rik60 »
After the switch back to SysV i don't have issues when updating through the web ui. The only thing is that sometimes the counter reach 100, then after a few seconds the dashboard is back with the updated version of the beta.
I am running Domoticz on a Rpi3B+ Trixie.
Issue is fixed. It should update to beta now perfectly again (at least mine does)
homeJLB
Domoticz version: 2024.7
Post by homeJLB »
I have try'd the webupdate but it goes to 100% and does not come back online.
My service file looks like this;
[Unit]
      Description=domoticz_service
[Service]
      #User=pi
      #Group=users
      ExecStart=/home/lauwers/domoticz/domoticz -www 8080 -sslwww 443 -log "/var/log/domoticz.log" -loglevel all -debuglevel normal,hardware,received
      WorkingDirectory=/home/lauwers/domoticz
      ExecStartPre=setcap 'cap_net_bind_service=+ep' /home/lauwers/domoticz/domoticz
      Restart=on-failure
      RestartSec=1m
      #StandardOutput=null
[Install]
      WantedBy=multi-user.target
from the command line I always used;
so without the .sh
● domoticz.service - domoticz_service
     Loaded: loaded (/etc/systemd/system/domoticz.service; enabled; preset: enabled)
     Active: active (running) since Sun 2026-04-05 19:49:49 CEST; 13h ago
    Process: 880175 ExecStartPre=setcap cap_net_bind_service=+ep /home/lauwers/domoticz/domoticz (code=exited, status=0/SUCCESS)
   Main PID: 880176 (domoticz)
      Tasks: 32 (limit: 3914)
        CPU: 8min 16.476s
     CGroup: /system.slice/domoticz.service
             └─880176 /home/lauwers/domoticz/domoticz -www 8080 -sslwww 443 -log /var/log/domoticz.log -loglevel all -debuglevel normal,hardware,received
My system is a Raspberry Pi 4 Model B Rev 1.2
with Debian GNU/Linux 12 (bookworm)
The next update I will look further,
For now updated from command line runs fine.
Kind Regards
Webgui update does not support systemd service.
You have to use the Sysv (init.d) method.
I remember now I have to update the wiki as some weeks ago it was switched to systemd but failed somehow for updates so it was decided to go back to Sysv.
homeJLB
Post by homeJLB »
I thought the init.d-method was deprecated.
I believe that it works easier with systemd, but its just a opinion.
Kind Regards
