Problem with Icons in 2026.1
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
I already wrote this in the 2026.1 release thread, but there was no answer to it, so I think, it would be better under bugs and problems. I updated to 2026.1 and my windows sensor icons don't work. The text ist changed from closed to opened, but the icon doesn't change. I tried it with the default icon (door), it happened the same. I resetted the browser cache, no change.I saw, that someone else also wrote about this in the release thread. Is this a known problem, and if, will it be fixed?
gmarchionni
Re: Problem with Icons in 2026.1
Post by gmarchionni »
hi,
it's already fixed in latest beta.
harrykausl
Thanks for the info, will there be a support release in the near future?
Domoticz version: 2026.3
That is never done unless it is a critical issue that should be fixed.
You can update to current beta and not update again until the next stable is released.
