If you’ve ever dealt with a Zigbee bulb falling off the network, or a Wi-Fi sensor lagging because of interference, you know that wires are still king when it comes to mission-critical home automation.
We’d like to introduce the DomBus ecosystem, natively developed for Domoticz through the Creasol DomBus plugin, available from github and also from Python Plugin Manager. More info in the wiki, https://wiki.domoticz.com/Creasol_Dombus
While Wi-Fi and Zigbee are great for retrofitting, a truly stable smart home (especially for lighting, shutters, and security) benefits from a wired backbone.
- Zero RF Interference: No more “Entity not available” because someone turned on the microwave.
- Ultra-Low Latency: Instant response times for switches, alarm sensors, relays, ...
- Power over Bus: A single thin 4-wire cable for 12/24V power supply + Data communication, easy to connect with any bus topology (linear, star, mixed), much better than LAN cable. No batteries to change. Ever.
- Ultra-Low power: our modules consumes typically less than 15mW when operating, +75mW for each relay output in ON state. DomBus36 consumes less than 750mW with all 12 relays ON! Do you know how much a Shelly/Sonoff/ESP32 consumes?
We know that hardware is only as good as its integration. Our DomBus python plugin works perfectly with Domoticz since 2019, successfully managing dozens of modules corresponding to several hundreds of devices without any pain or fault.
- Plug & Play: It talks directly to your USB-RS485 adapter.
- Your DomBus modules (DomBus12, DomBus31, DomBusTH, DomBusEVSE to make your DIY wallbox, etc.) appear automatically in Domoticz as soon as you connect them
- 100% Local: No cloud, no external APIs. If your internet goes down, your house keeps running perfectly.
Our modules are designed to fit into your electrical cabinet (DIN rail) or behind wall switches:
- Multi-I/O Modules: Control 12+ inputs/outputs from a single module.
- Climate Control: temperature sensors (NTC probes) connected to analog inputs, or temperature/humidity sensor already integrated in the very tiny DomBusTH board.
- Energy Management: Interface with heat pumps, boiler, meters via solid, wired connections.
- Electric Vehicle Charinging: full-feature EVSE module to make your full-features DIY wallbox
- Single/Dual Axis Solar Tracker controller: using DomBusTracker2 module
- Our store with all DomBus modules and starter kits: store.creasol.it
For any support request, please reply on this topic or contact Creasol by Telegram or Whatsapp.
