beta 17447 to 17452 Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Dave21w
- Domoticz version: Stable
beta 17447 to 17452
Update from 17447 to 17452 Domoticz fails to restart, tried on 2 different beta installs, same on both. a sudo systemctl restart domoticz does start it though.
- Domoticz version: 2026.3
Re: beta 17447 to 17452
Did you update over webgui? Did you try to run manually:
sudo ./updatebeta
What hardware/OS are you running as it could be related to viewtopic.php?t=44457
sudo ./updatebeta
Andreotti
- Domoticz version: latest
Same here. 17452 does not start automatic. Manual restart does the trick.
Raspberry Pi 4 with Trixie13.4
Rik60
Maybe you have to wait a while, I have seen that when the counter reach 100, that when the counter could be at 130, the dashboard is back without a service restart
Dave21w
Update was done via the gui, have to wait until another update to see if it actually restarts then
Dave21w
Just updated to 17458 and now restarts OK
Andreotti
I waited long enough but I needed a manual restart on 17458 also.
The log says the service has started, but it looks like there's no connection to the database.
Rik60
Hmm, yesterday i did an update to 17437 without problems. Now the update again through the web ui, Domoticz didn't come online. Had to do a service restart. There is still something going on with the update procedure when using the web ui. After the service restart Domoticz was on 17459.
Andreotti
Same with 17459.
The log says the service has started.
But the files domoticz.db-shm and domoticz.db-wal are missing. After manual restart they are there again.
- gizmocuz
They suppose to be missing when the Domoticz service is shutdown properly. (you can google what these extensions mean)Andreotti wrote: Friday 20 March 2026 14:04 Same with 17459.
try the following
sudo killall -9 domoticz
sudo service domoticz.sh start
This should get you up and running correctly, next try the web update
If it still does not work, just issue
cd domoticz
./updatebeta
rene2716
Next update 17477 won't install either, no progress shown and keeps coming back
Dave21w
Update to 17484 via WebUI all good
Rik60
No issues anymore. Updating though the web ui was ok. Tested with Bookworm and Trixie. Running Beta 17492 now.
Rik60
Updating through the web ui failed. After some time: No internet connection...The update log file showed that the update was finished. Updating was from 17494 to 17497. A domoticz service start did not help, had to do a service restart.
- update.log
- (25.03 KiB) Downloaded 65 times
- gizmocuz
@Rik
Just wanting to point out that I (and others) with multiple installations do not experience this issue.
As you are already in discussion with us on Github, it is not needed to create a forum post.
(cross posting is not allowed, and causes us double the work)
