Devices not shown on tab pages
BartSr
- Domoticz version: V2024.7
There are a number of devices which are in devicelist but not shown on a page. Devices don't have a name starting with $
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2026.3
Re: Devices not shown on tab pages
Did you check the assigned devices list for your account in menu setup - users? It should be empty, if not you only see the assigned devices.
BartSr
Walter, I don't know exactly what you mean but I forgot to mention these devices were visible before all the time.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Did you check the menu I suggested and did you check the device list attached to the user you are logged in with? See wiki:
https://wiki.domoticz.com/User_Management and https://wiki.domoticz.com/Setting_up_Device_sharing
BartSr
is it this you mean?
- Schermafbeelding 2026-03-11 171215.png (165.67 KiB) Viewed 4168 times
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Thorgal789
- Target OS: -
Ha yes, I realy dislike this feature too.
If I m right all thoses devices are invisible, you need to move them from left to right.
On my side I m admin, and I need to enable all new device one by one.
BartSr
On the left all devices are listed.
On the right nothing has been selected
But....... I have lots of devices (but not all) still visible
Before it was all OK e.g. visible to me
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
If the right is empty for an admin (no assigned devices) it should see all active devices in the tabs when you logon with that account. Then no further action is needed when new devices are created (and activated).
If you need device sharing you should not use an admin user to do this.
@BartSr what devices are you missing on the tabs? Do they have something in common, like new, or from a specific gateway? Or is it just some random devices you do not see?
Are you using other accounts?
BartSr
it seems random but most are just temp devices, some of them even idx 1,2,3,....
I checked database with db browser
all devices are there but the once's missing on the tabs are not updated since a week
I am admin, there are 3 more admins
I updated the database into another (test desktop) machine
same problems
then I removed all other admins
no effect
so I expect there's something wrong with database
same problems
no effect
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- gizmocuz
If you want, please send me a PM on our slack channel
https://join.slack.com/t/domoticz/share ... G2dBSOTRwg
Do mention the link to this topic
BartSr
Done a second ago
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Problem has been solved thanks to Gizmocus.
First to mention:
it has been my own fault.
I am having in hardware : dummy.
Then I needed a new hardware: P1 LAN.
My mistake: iso creating a new hardware for P1 I modified the hardware of dummy into P1 LAN device.
Because the P1 did not what I expected I disabled 'new' P1.
As a result ALL dummy devices where no longer visible.
Changing P1 back to hardware 'dummy' and enabeling this hardware brought back All devices.
First to mention:
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
