Please use template to report bugs and problems. Post here your questions when not sure where else to post Only for bugs in the Domoticz application! other problems go in different subforums!
Forum rules
Using beta 17290 nor a pid file nor a log file can be written to in 'default' locations. With 'default' I mean /var/run for the pid file and /var/log for the logfile. Defining those paths in ExecStart like:
A solution could be to run Domoticz as root (comment out User=pi and Group=pi in the domoticz.service file). I don't know if this is a safe solution, please advice.
With beta 17342 Domoticz switched back to SysV init (init.d). So everything is 'normal' again. Run install program after beta update to make the change back from systemd. The domoticz.sh file in /etc/init.d may need some adaptations since it's written back as the default.
