How to find domoticz log file
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
meal
Domoticz version: 2025.2
Post by meal »
1 - Context
Domoticz V2025.2 (build 17277) running on bookworm
Build Hash fac6d8f
Compile Date 2026-02-26 06:42:05
dzVents Version 3.1.11
Python Version 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
2 - How to find domoticz log file
I switched from the deprecated mean to create domoticz service using the /etc/init.d/domoticz.sh file to the preferred one in /etc/systemd/system/domoticz.service.
Previously i recorded domoticz messages in "/var/log/domoticz.log" by setting in domoticz.sh file the line:
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
Now when using /etc/systemd/system/domoticz.service I see the domoticz messages in domoticz UI but I am not able to find in which file they are stored. I also would like to define the file name supporting these messages.
I would be grateful if someone could help me or give me a hint.
BR
meal
Domoticz version: 2025.1
Re: How to find domoticz log file
It should be defined in the EnvironmentFile (eg /home/pi/domoticz.env)
See https://wiki.domoticz.com/Linux#Option_ ... Preferred)
the location of the environment file is set in the systemd configuration file eg
meal
Post by meal »
@waltervl
Many thanks for the information.
To be more precise if I want to store the domoticz messages in /tmp/domoticz.log what do I have to set in /home/pi/domoticz.env file ?
meal
Seems I was wrong according AI:
To set the Domoticz log file using a systemd service configuration, you must modify the ExecStart directive within the service unit file to include the -log command-line parameter.
1. Locate the Service File
The Domoticz systemd service file is typically located at:
2. Configure the Log File Path
Edit the file using a text editor like nano:
sudo nano /etc/systemd/system/domoticz.service
Find the ExecStart line and append the -log and -loglevel parameters. For example:
ini
[Service]
ExecStart=/home/pi/domoticz/domoticz -www 8080 -log /var/log/domoticz.log -loglevel normal,status,error
-log <path>: Specifies the full path to the log file.
-loglevel <levels>: Sets the verbosity (e.g., normal,status,error,debug).
3. Set Permissions (not sure this is needed)
Ensure the directory where the log will be stored exists and that the user running Domoticz (often pi or domoticz) has write permissions to it:
sudo touch /var/log/domoticz.log
sudo chown pi:pi /var/log/domoticz.log
4. Apply Changes
Reload the systemd manager configuration and restart the service:
Reload daemon:
sudo systemctl daemon-reload
Restart service:
sudo systemctl restart domoticz.service
meal
Post by meal »
Many thanks
meal
Doler
Post by Doler »
@waltervi:
Should logrotate not be adapted to the use of systemd? I'm now using
/var/log/domoticz.log {
	missingok
	daily
	rotate 7
	compress
	delaycompress
	notifempty
	postrotate
		if [ -x /usr/sbin/invoke-rc.d ]; then \
			invoke-rc.d domoticz.sh reload > /dev/null; \
		else \
			/etc/init.d/domoticz.sh reload > /dev/null; \
		fi
	endscript
in /etc/logrotate.d. This refers to (now non-existing) /etc/init.d/domoticz.sh as start for the service.
How to change?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Kedi
Post by Kedi »
I added to the system unit file:
ExecReload=/bin/kill -HUP $MAINPID
Now this command will work in the logrotate file
        postrotate
                sudo systemctl reload domoticz.service
        endscript
At least with the latest beta's. I am running 17252
Kedi
Post by Kedi »
I was wrong with the "kill -HUP" solution, it stops domoticz, my monit started then domoticz again.
This solution is not yet present in version 17252.
