How to find domoticz log file
meal
- Domoticz version: 2025.2
1 - Context
Domoticz V2025.2 (build 17277) running on bookworm
Build Hash fac6d8f
Compile Date 2026-02-26 06:42:05
dzVents Version 3.1.11
Python Version 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
2 - How to find domoticz log file
I switched from the deprecated mean to create domoticz service using the /etc/init.d/domoticz.sh file to the preferred one in /etc/systemd/system/domoticz.service.
Previously i recorded domoticz messages in "/var/log/domoticz.log" by setting in domoticz.sh file the line:
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
Now when using /etc/systemd/system/domoticz.service I see the domoticz messages in domoticz UI but I am not able to find in which file they are stored. I also would like to define the file name supporting these messages.
I would be grateful if someone could help me or give me a hint.
BR
1 - Context
Build Hash fac6d8f
BR
meal
- Domoticz version: 2026.3
Re: How to find domoticz log file
It should be defined in the EnvironmentFile (eg /home/pi/domoticz.env)
See https://wiki.domoticz.com/Linux#Option_ ... Preferred)
the location of the environment file is set in the systemd configuration file eg
meal
@waltervl
Many thanks for the information.
To be more precise if I want to store the domoticz messages in /tmp/domoticz.log what do I have to set in /home/pi/domoticz.env file ?
meal
Seems I was wrong according AI:
To set the Domoticz log file using a systemd service configuration, you must modify the ExecStart directive within the service unit file to include the -log command-line parameter.
1. Locate the Service File
The Domoticz systemd service file is typically located at:
2. Configure the Log File Path
Edit the file using a text editor like nano:
Find the ExecStart line and append the -log and -loglevel parameters. For example:
ini
-log <path>: Specifies the full path to the log file.
-loglevel <levels>: Sets the verbosity (e.g., normal,status,error,debug).
3. Set Permissions (not sure this is needed)
Ensure the directory where the log will be stored exists and that the user running Domoticz (often pi or domoticz) has write permissions to it:
4. Apply Changes
Reload the systemd manager configuration and restart the service:
Reload daemon:
Restart service:
sudo nano /etc/systemd/system/domoticz.service ini
[Service]
ExecStart=/home/pi/domoticz/domoticz -www 8080 -log /var/log/domoticz.log -loglevel normal,status,error-loglevel <levels>: Sets the verbosity (e.g., normal,status,error,debug).
sudo touch /var/log/domoticz.log
sudo chown pi:pi /var/log/domoticz.log Reload the systemd manager configuration and restart the service:
Reload daemon:
sudo systemctl daemon-reloadCode: Select all
sudo systemctl restart domoticz.serviceDomoticz running on Udoo X86 (on Ubuntu)
Doler
@waltervi:
Should logrotate not be adapted to the use of systemd? I'm now using in /etc/logrotate.d. This refers to (now non-existing) /etc/init.d/domoticz.sh as start for the service.
How to change?
/var/log/domoticz.log {
missingok
daily
rotate 7
compress
delaycompress
notifempty
postrotate
if [ -x /usr/sbin/invoke-rc.d ]; then \
invoke-rc.d domoticz.sh reload > /dev/null; \
else \
/etc/init.d/domoticz.sh reload > /dev/null; \
fi
endscript
How to change?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Kedi
- Domoticz version: latest
I added to the system unit file:
Now this command will work in the logrotate file
At least with the latest beta's. I am running 17252
ExecReload=/bin/kill -HUP $MAINPIDCode: Select all
postrotate
sudo systemctl reload domoticz.service
endscript
Kedi
I was wrong with the "kill -HUP" solution, it stops domoticz, my monit started then domoticz again.
This solution is not yet present in version 17252.
Doler
My test system is on beta 17277 and the system file already has the "kill-HUP". I adapted the logrotate file according your suggestion but I cannot test since nothing is written to the log although it should according the execstart in the system unit file: In another topic (viewtopic.php?f=6&t=44419&sid=cb11b85db ... b676e161fd) it was suggested to adapt the monit configuration to the new systemd use.
[Unit]
Description=Domoticz Home Automation System
Documentation=https://www.domoticz.com/wiki
After=network-online.target time-sync.target
Wants=network-online.target
[Service]
Type=simple
User=pi
Group=pi
WorkingDirectory=/home/pi/domoticz
ExecStart=/home/pi/domoticz/domoticz -www 8080 -sslwww 443 -log /var/log/domoticz.log -loglevel normal,status,error
AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_NET_RAW
Restart=on-failure
RestartSec=5
[Install]
WantedBy=multi-user.target
