Hi I am using a 3 fase Amp device Type " Current, CM113,Electrisave ".
It shows as expected the Amp values but if no current in all fases it just shows only one time zero. Is this as intended or is it a bug.
-Bart
3 fase Amp meter shows just one zero iso 0,0,0
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2026.3
Re: 3 fase Amp meter shows just one zero iso 0,0,0
Does it show then a single 0 value only on display or also in the device list (menu setup - devices)?
BartSr
Both device list as well as dashboard and utility page are showing '0.0' identical
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
