[Unit]
Description=Domoticz Home Automation Service
After=network-online.target
[Service]
Type=simple
User=pi
Group=pi
WorkingDirectory=/home/pi/domoticz
ExecStart=/home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443 -pidfile /var/run/domoticz/domoticz.pid
Restart=on-failure
[Install]
WantedBy=multi-user.target
domoticz.service - Domoticz Home Automation Service
Loaded: loaded (/etc/systemd/system/domoticz.service; enabled; preset: enabled)
Active: inactive (dead) since Sun 2026-02-22 14:10:25 GMT; 5min ago
Duration: 191ms
Invocation: 25c5fb4ab80c413489635312fe0ac205
Process: 1079 ExecStart=/home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443 -pidfile /var/run/domoticz/domoticz.pid (code=exited>
Main PID: 1079 (code=exited, status=0/SUCCESS)
CPU: 545ms
Feb 22 14:10:23 rpidhcpserver systemd[1]: Started domoticz.service - Domoticz Home Automation Service.
Feb 22 14:10:23 rpidhcpserver domoticz[1079]: 2026-02-22 14:10:23.847 Status: Domoticz V2025.2 (c)2012-2025 GizMoCuz
Feb 22 14:10:23 rpidhcpserver domoticz[1079]: 2026-02-22 14:10:23.847 Status: Build Hash: e63981b18, Date: 2025-10-13 10:42:57
Feb 22 14:10:23 rpidhcpserver domoticz[1079]: 2026-02-22 14:10:23.847 Status: Startup Path: /home/pi/domoticz/
Feb 22 14:10:23 rpidhcpserver domoticz[1079]: domoticz: Domoticz is starting up....
Feb 22 14:10:23 rpidhcpserver domoticz[1079]: Domoticz is starting up....
Feb 22 14:10:23 rpidhcpserver domoticz[1080]: Domoticz is exiting...
Feb 22 14:10:25 rpidhcpserver systemd[1]: domoticz.service: Deactivated successfully.
home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443 -pidfile /var/run/domoticz/domoticz.pidCode: Select all
pi@rpidhcpserver:~/domoticz $ /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443 -pidfile /var/run/domoticz/domoticz.pid
2026-02-22 14:17:42.839 Status: Domoticz V2025.2 (c)2012-2025 GizMoCuz
2026-02-22 14:17:42.839 Status: Build Hash: e63981b18, Date: 2025-10-13 10:42:57
2026-02-22 14:17:42.839 Status: Startup Path: /home/pi/domoticz/
#Type Path Mode UID GID Age Argument
d /run/domoticz 0755 pi pi - -
Chris
