dzvents lua scripts are not triggered anymore (build 17186)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
rugspin
Post by rugspin »
since the update to v2025.2 (build 17186), all my dzvents lua automations are not triggered anymore. For example I see that a switch changes state, but the lua script is not triggered. (Also the CPU is much lower than before the update)
Anybody else seeing the same issue?
arnout
Re: dzvents lua scripts are not triggered anymore (build 17186)
Post by arnout »
I have exactly the same issue, is there any way to downgrade to an older bèta version?
meal
Domoticz version: 2025.2
Post by meal »
The same in Domoticz version 17188
LUA event are not triggered
BR
meal
rugspin
Post by rugspin »
arnout wrote: Thursday 19 February 2026 20:06 I have exactly the same issue, is there any way to downgrade to an older bèta-vuile version?
I'm not exactly sure, but I think there is no real downgrade to older versions in form of a script.
The way to be able to do this, is a full backup of the domoticz installation folder, make the update and if something goes wrong revert back to the backup.
Now, there is a issue filed on github, so I will just wait a little. There was a lot of work done recently and I'm sure the next update will fix the issue.
meal
Post by meal »
I created the issue #6587 and found a fix to that issue which I tested successfully on my system.
We have to wait to the next release implementing the fix I suggested.
BR
meal
Domoticz version: 2026.3
rugspin wrote: Thursday 19 February 2026 20:27
For the next time you want to revert back to a previous version check the wiki https://wiki.domoticz.com/Raspberry_Pi# ... ect_update
meal
Post by meal »
The issue has been fixed in Domoticz Version 17192
BR
meal
bboy19
Post by bboy19 »
It's not working on ver. 17366. I had to rollback to ver. 17030
Henry
Domoticz version: 2024.7
Post by Henry »
I'm not sure if this is related, but I upgraded to V2025.1 and now the dzvents scripts aren't triggered anymore. Due to an old pi os I can't upgrade to a newer version (working on that).
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
rugspin wrote: Thursday 19 February 2026 19:27 Hi all,
What does your uptime counter says? (goto setup>about)
In my case the external watchdog kept restarting domoticz every ~2 minutes.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
