Domoticz doesn't start after update beta Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Rik60
Domoticz version: 2026.3
Post by Rik60 »
After a update from beta 17099 to 17189 Domoticz did not restart. Did the update throuh the settingsscreen. Counter counted until 100, then the message update failed, no internet connection....
After a domoticz service restart was domoticz running normaal on the downloaded beta 17189. I thought this problem was solved? Attached the update.log and domoticz crash log
domoticz_crash.log
(5.51 KiB) Downloaded 68 times
update.log
(2.18 KiB) Downloaded 68 times
Re: Domoticz doesn't start after update beta
As mentioned in the history text you probably have to update twice due to libmosquitto library addition when you are on an older updatebeta script.
So next time the web update will/should run successful.
Edit: I now see the log and see the error:
gdb: warning: Couldn't determine a path for the index cache directory.
No idea what is happening here....
gizmocuz
Post by gizmocuz »
Did you run updatebeta twice, and did that solve the issue?
Rik60
Post by Rik60 »
When i was building a test sd card and did some installations, release and beta, from the setting screen, there where no issues. I am not shure because did a lot of testing yesterday. Have to do that again.
Rik60
Post by Rik60 »
Created a new sd card with Trixie 64 bit lite. Installed Domoticz 2025.2 stable. Through the settingsscreen (check for updates) installed beta 2025.2 17175. No problems, during the countdown the dashboard came back normaal. No issues.
Rik60
Post by Rik60 »
Updated to the last beta 2025.2 17204. No issues.
