Tasmota device ("Hichi" infraread head) brings error
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
I have an infraread reading head on my electric meter ("Hichi" with Tasmota). Transfering the data via MQTT to Domotics works, but for at least one of the figures I get this error:
Error: Invalid Number sValue: '%' for device idx: '%'
Error: GetJSonDevices: exception occurred : 'stoull'
For those of you who are savvy with Tasmota: This is the code of the customized script that runs there and it displays correct data in the Tasmota web interface:
>D
>B
=>sensor53 r
>M 1
+1,3,s,0,9600,,1
1,77070100010800FF@100000000,Zählerstand Import ,kWh,1_8_0,8
1,77070100010801FF@1000,Zählerstand Import T1 ,kWh,1_8_1,8
;1,77070100010802FF@100000000,Energie Bezug T2,kWh,1_8_2,8
1,77070100020800FF@100000000,Zählerstand Export,kWh,2_8_0,8
1,77070100100700FF@1,Summe Verbrauch 🔌,W,16_7_0,16
1,77070100240700FF@1,akt. Verbrauch L1,W,36_7_0,16
1,77070100380700FF@1,akt. Verbrauch L2,W,56_7_0,16
1,770701004C0700FF@1,akt. Verbrauch L3,W,76_7_0,16
But even the non-customized Script from the Tasmota wiki shows the same error:
https://tasmota.github.io/docs/Smart-Me ... d3-obissml
Any hints are highly welcome
Stop, look and listen.
Domoticz version: 2026.3
Re: Tasmota device ("Hichi" infraread head) brings error
Please supply the MQTT message payloads that give issues.
You can do that with for example MQTT Explorer https://wiki.domoticz.com/MQTT#Debugging_MQTT
Edit The "stoull" error when showing a graph is related to incorrect values in your database. Search the forum for this error.
Edit: 2 see for example viewtopic.php?p=331228&hilit=stoull#p331228
imautohuttraeger
In MQTT ExplorerI have found two entries for this tasmota device:
{"ip":"192.168.1.112","dn":"Hichi_Stromzaehler","fn":["@@4ecwdbR{ *```@`f@@|@` d0x",null,null,null,null,null,null,null],"hn":"Hichi-Lesekopf-6802","mac":"F4CFA2DF5A92","md":"Sonoff Basic","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"13.2.0","t":"Hichi_Lesekopf","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":1,"117":0},"lk":0,"lt_st":0,"bat":0,"dslp":0,"sho":[],"sht":[],"ver":1}
and
{"sn":{"Time":"2026-02-09T22:00:54","SML":{"1_8_0":10409.59198526,"1_8_1":0.10408596,"1_8_2":0.00000995,"2_8_0":5620.10674508,"2_8_0":5620.10674508,"16_7_0":15,"36_7_0":-51,"56_7_0":-29,"76_7_0":95,"96_1_0":"090145425a0100241cd8"}},"ver":1}
Anything strange here form an expert point of view?
I dont know. How do you import the data into Domoticz? As this seems a payload that is not designed for Domoticz's default MQTT interface. https://wiki.domoticz.com/MQTT#MQTT_to_Domoticz
Do you use MQTTMapper plugin? Or the MQTT AD gateway?
imautohuttraeger
For Tasmota devices I use the "configure domoticz" section of the web interface. There I type in the IDX of the virtual domoticz devices. See screenshot (but the caption is not corresponding to the values here because it is not a switch device. It is about power in Watt and meter counts of import and export in kWh
xyzScreenshot 2026-02-10 150238.png (69.33 KiB) Viewed 3000 times
I have no idea how this works.
Domoticz MQTT expects something like below in MQTT Domoticz/in topic (when using default MQTT settings. Read the Domoticz Wiki for more info.
{  "command": "udevice",  "idx" : 7,  "nvalue" : 0,  "svalue" : "90;2975.00" }
or short:
{  "idx" : 7,  "nvalue" : 0,  "svalue" : "90;2975.00" }
You perhaps have to change something on the Tasmota side?
In the following Topic you want to use the MQTT mapper plugin to map values from tasmota into Domoticz. viewtopic.php?p=307270#p307270
So check that.
imautohuttraeger
waltervl wrote: Tuesday 10 February 2026 16:16 In the following Topic you want to use the MQTT mapper plugin to map values from tasmota into Domoticz. viewtopic.php?p=307270#p307270
So check that.
You are right. It was my intention to user MQTT Mapper but I have to admit that I haven't done it because I have too much concerns that editing the mqttMapper.json file for each device is too sophisticated and time intensiv for me ... However maybe I should finally start now ...
imautohuttraeger
waltervl wrote: Tuesday 10 February 2026 13:23 Please supply the MQTT message payloads that give issues.
Thx, this really seems to be a hint that goes into the right direction. I could now verify that opening the log graph causes an error. But not the "stoull" but this:
It occurres with several different energy devices, no matter from which manufacturer or OS (Tasmota, Shelly). But not each one. Very strange ...
EDIT: Meanwhile I have recognizes, that the error can be forced by opening a graph log. But not only. Both errors are coming even without interaction, but only from time to time.
Last edited by imautohuttraeger on Wednesday 11 February 2026 12:50, edited 2 times in total.
imautohuttraeger
I have checked the databsae according to the troubleshooting page
https://wiki.domoticz.com/Troubleshooti ... k_database
The list of tables does not show "Preferences"
pi@Raspberry:~/domoticz $ sudo sqlite3 domoticz.db  'SELECT name as Tablename ,SUM("pgsize")/4096 Size FROM "dbstat" WHERE name IN (SELECT name FROM "sqlite_master" WHERE type == "table" ) GROUP BY name HAVING Size > 10 ORDER BY size DESC;'
lost_and_found|7391
Temperature_Calendar|1132
Meter_Calendar|923
LightingLog|776
Meter|594
Floorplans|390
Percentage_Calendar|272
MultiMeter_Calendar|225
Temperature|181
EventMaster|79
Wind_Calendar|70
Percentage|65
Rain_Calendar|56
UV_Calendar|37
SceneLog|20
DeviceStatus|19
Rain|16
UV|15
KWHStats|13
Wind|12
And the integrity check and foreign key check are showing no errors:
pi@Raspberry:~/domoticz $ sudo sqlite3 domoticz.db "PRAGMA integrity_check(10000)"
ok
pi@Raspberry:~/domoticz $ sudo sqlite3 domoticz.db "PRAGMA foreign_key_check"
However I have proceeded the repair process anyhow, but of course with no result.
Is there anything else I can do?
It is not a error in the database, there is an incorrect value for reporting in the database.
imautohuttraeger
Meanwhile I figured out, that this has nothing to do with the "Hichi" device and the tasmota script. The error also occurs. When, this "Hichi" device is off.
Latest "news" on the "svalue" error is here:
viewtopic.php?f=6&t=44471
