Communicating with home assistant
akamming
Post by akamming »
Just 2 Share the knowledge:
I like home assistant because of the big community, the nice dashboarding and the many many integrations, but i also like domoticz e.g. because of the P1 integration (and the nice reports on it), and the easy way of scripting (HA has no alternative for something like dzVents).
Since I cannot choose between the 2 i decided to use the benefits of both. This is how i do it:
1. Since both support the MQTT AD protocol: For every integration which support is: Add the devices by MQTT AD. This will make the devices available in both instances
2. For those who don't: Using the MQTT Client Interface integration in domoticz to connect the 2. Note: For this to work every device needs to have it's own state topic. So in the settings for MQTT CLient interface, set Publish Topic either to "Index" or "Name"
By setting the interface under 2 you now have the perfect mechanism to have the 2 instances to talk to each other:
For sending devices updates from HA to Domoticz:
- Create a virtual device in domoticz (mirroring the device in home assistant)
- Create an automation in home assistant with the folling properties
  • Trigger: The sensor change
  • Condition: None
  • Action: mqtt.publish with the topic "domoticz/in" and as payload something like { "command": "udevice", "idx": <the idx of your virtual sensor in domoticz>, "nvalue": 0, "svalue": "{{ states.<the sensor name of your sensor in home assistant>.state }}"}
For sending device updates from Domoticz to HA:
- Add the line "mqtt: !include mqtt.yaml" to you homeasistant configuration.yaml
- Create the devices you'd like by describing them in the mqtt.yaml file. :
sensor:
# Gas usage
  - state_topic: "domoticz/out/<index of your domoticz sensor>"
    name: "<name of the device>"
    value_template: '{{ value_json.svalue1  }}'
    unit_of_measurement: '<unit of measurement>'
    device_class: <device class>
    state_class: <state class>
  - <repeat the above lines for every sensor you would like to read from domoticz>
e.g. hereby the example of which i currently use to import my utility devices to home assistant:
#P1 meter
sensor:
  - state_topic: "domoticz/out/6"
    value_template: '{{ value_json.svalue1 | float / 1000  }}'
    unit_of_measurement: "kWh"
    device_class: energy
    state_class: total_increasing
    value_template: '{{ value_json.svalue2 | float / 1000 }}'
    value_template: '{{ (value_json.svalue2 | float + value_json.svalue1 | float ) / 1000 }}'
    value_template: '{{ value_json.svalue3 | float / 1000 }}'
    value_template: '{{ value_json.svalue4 | float / 1000 }}'
    value_template: '{{ (value_json.svalue4 | float + value_json.svalue3 | float) / 1000 }}'
    value_template: '{{ value_json.svalue5 }}'
    unit_of_measurement: "W"
    device_class: power
    state_class: measurement
    value_template: '{{ value_json.svalue6 }}'
    device_class: power
# Gas usage
  - state_topic: "domoticz/out/10"
    name: "Gas Verbruik"
    unit_of_measurement: 'm³'
    device_class: gas
# Water usage
  - state_topic: "domoticz/out/598"
    name: "Water Verbruik"
    unit_of_measurement: 'L'
    device_class: water
#Solar Panels
  - state_topic: "domoticz/out/31"
    name: "Solaredge Delivery Total"
    name: "Solaredge Actual Delivery"
    device_class: power
Have fun! I am very happy now that i can use the strengths of both Home Assistant and Domoticz using this config!
solarboy
Domoticz version: 2024.6
Re: Communicating with home assistant
Post by solarboy »
Nice work, I'll give this a try.
akamming
Post by akamming »
Just found out how publish a domoticz switch as a MQTT switch in home assistant: Add the following to your mqtt.yaml file (see instructions above in this topic how to create that file in HASS):
switch:
  - state_topic: "domoticz/out/<idx>"
    value_template: "{% if value_json.nvalue==1 -%}ON{%- else -%}OFF{%- endif %}"
    command_topic: "domoticz/in"
    unique_id: "<uniqueid>"
    command_template: "{ \"command\": \"switchlight\", \"idx\": <idx>, \"switchcmd\": \"{{ \"On\" if value==\"ON\" else \"Off\" }}\" }"
make sure to replace
  • <idx> with the idx of the switch in domoticz
  • <unique_id> with some unique identifier (create whatever you want, as long as it's unique ;-))
  • <name> with the name you would like the switch to have in HASS
also make sure the "Prevent Loop" setting in your mqtt client gateway hardware setting is set to false, otherwise synchronisation might fail between HASS and domoticz
Stiens
Post by Stiens »
Great to read about integrating Dz with HA. I'm having the same dilemma, dzvents is too valuable and usefull :-)
Perhaps i am missing something about the integration from Dz to HA.
In my config the smart meter P1 is connected to Domoticz. The P1 data must be send to Home Assistant (HA) using MQTT. In HA i added a mqtt.yaml using the instructions from @akamming in this thread.
My question: what must be setup on the Domoticz site to send the P1 values to MQTT?
Thx
BartSr
Domoticz version: V2024.7
Post by BartSr »
For what it's worth:
I am using for many years already espeasy as an interface between sensors and domoticz. Since about some months in espeasy there is also an openhabcontroler enabeling interfacing with HA.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Stiens
Post by Stiens »
In the Hardware section of Domoticz MQTT Auto Discovery Client Gateway is not what you need. Add MQTT Client Gateway (without AD). Then in the Setup part choose the device to publish (to mqtt).
Stiens
Post by Stiens »
Also configure "Publish Topic:" to "index" (default is "Flat") this adds the IDX number to the topic (domoticz/out/<idx>)
In HA find the topics in Settings / Devices & Services. Choose Entities. There is an Ungrouped section with the 8 (in my case) topics. However they are Unmanagable from the UI because of the missing unique ID.
