New plugin : Fully Kiosk Browser
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I've release a first version of a plugin to control Fully Kiosk Browser.
This app can be used with Dashticz as kind of browser with a lot of functionalities
Let me know if something is not working or you like to have other features
Check out over here for the plugin
https://github.com/MadPatrick/domoticz_fullykiosk
Domoticz version: 2026.3
Re: New plugin : Fully Kiosk Browser
Sorry, I fail to understand how this could work.
How does the plugin knows from what display device it can get for example the screen on/off value?
Perhaps you add more info in the readme what you can do with the plugin?
madpatrick
By the device IP that you fill in in the setup
If you are using Fully kiosk it is straight forward.
madpatrick
Pushed version 1.1 in Git
Added: Battery Charging Control
- Automatically controls tablet charging based on battery percentage
- Stops charging at a random level between 80–90%
- Resumes charging at a random level between 20–30%
- Randomized thresholds help avoid keeping the battery at the same charge levels all the time, reducing battery wear
- Requires a charger that can be switched on/off (e.g. a smart plug)
Added to plugin wiki
