I am happy to report that build 16988 seems to have solved the problem for me; I ran this for the past week Domoticz during which did not go down. Now updated to 16993. The Hue bridge (V2, white square) runs firmware 1.74.1974142030.
Kind regards,
Paul
Philips Hue related crashes
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Woody1
- Domoticz version: 2025.2
Re: Philips Hue related crashes
Pi 4b, 8Gb, Trixie Lite, POE, Domoticz 2025.2 / 16954
Evohome/HUE/Daikin AC/P1
Peter2
I can confirm that the problem seems to have been solved (build 16990). Domoticz has been running stable for 8 days now without any crashes.
I have an old Philips HUE bridge (v1 round white) running fine on domoticz for over 10 years...
I installed a fresh raspberry PI with latest Domotiz in august 2025...
Today i accidentily upgraded Domoticz (check updates in stead of more options in menu), and now HUE hardware is no longer working ...
Can i downgrade Domoticz back to august version ????
- Domoticz version: 2026.3
Yes, during update it creates a full backup of your Domoticz environment. Restoring that backup should revert the Domoticz version https://wiki.domoticz.com/Raspberry_Pi# ... ect_updateKorrel wrote: Friday 23 January 2026 19:44 I have an old Philips HUE bridge (v1 round white) running fine on domoticz for over 10 years...
Great ! That fixed it ! Thank you very much ...waltervl wrote: Friday 23 January 2026 19:55Yes, during update it creates a full backup of your Domoticz environment. Restoring that backup should revert the Domoticz version https://wiki.domoticz.com/Raspberry_Pi# ... ect_updateKorrel wrote: Friday 23 January 2026 19:44 I have an old Philips HUE bridge (v1 round white) running fine on domoticz for over 10 years...
Gravityz
today i got the mandatory hue bridge upgrade which you can not skip.
first upgraded to domoticz 17053
after i checked if everything was working i upgraded the hub to 1.75.1975104000
sofar everything working stable
UPDATE:SPOKE TO SOON.
it seems domoticz it getting sluggish
Also the triggers which devices generate to launch a script are sometimes missed.
i have has this with 3 different scripts.
the devices which need to launch a script change their value/setting but nothing happens.
no types and these scripts are running for years now.
if i would make an educated guess is that something(HUE V2 api) is slowing down things and is interfering with the dzvents triggering mechanism
do other people have noticed this
also there are still sometimes hue errors in the log that the hub is not available
i cn not rollback because i updated the hue hub ans rolling back will crash domoticz
UPDATE: i have rolled back to 16782 and everything is runing like before. no hue problems at all but i still havce the lastest FW
i think they fixed something in fw 1.75 because everything is runnning smooth on port 80
