Problem with Parameters from XML
svd71
Post by svd71 »
hi All,
in my plugin I had build couple of parameters
    <params>
        <!-- Domoticz API -->
        <param field="DzAddress" label="Domoticz IP" width="200px" required="true" default="127.0.0.1"/>
        <param field="DzPort" label="Domoticz Port" width="80px" required="true" default="8080"/>
        <!-- MQTT Broker -->
        <param field="MqttAddress" label="MQTT Server" width="200px" required="true" default="127.0.0.1"/>
        <param field="MqttPort" label="MQTT Port" width="80px" required="true" default="1883"/>
        <param field="MqttUsername" label="MQTT Username" width="200px" required="false"/>
        <param field="MqttPassword" label="MQTT Password" width="200px" required="false" password="true"/>
.... and later in the code do the output of data to log:
Domoticz.Log("Plugin::onStart: Parameters: {}".format(repr(Parameters)))
and does not see my parameters line DzAddress, DzPort, MqttAddress, Mqttport, etc.
What I do wrong ?
BR
Domoticz version: 2026.3
Re: Problem with Parameters from XML
Only the parameters listed in the wiki are available https://wiki.domoticz.com/Developing_a_ ... Parameters
If you need custom paramaters you need to choose one of the mode1 to mode6 parameters.
svd71
Post by svd71 »
thank you!
