I had try to buil my own plugin and have problem python:
2026-01-04 13:47:55.608 Error: AlarmSirenaCamCtrl: (tMQTTalarm) failed to load 'plugin.py', Python Path used was '/home/svd/domoticz/plugins/TasmotaMQTTAlarmCtrl/:/usr/lib/python313.zip:/usr/lib/python3.13:/usr/lib/python3.13/lib-dynload:/usr/local/lib/python3.13/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.13/dist-packages'.
About my environment:
RPi 3B with 1Gb, Trixie
Python 3.13.5
Domoticz Version: 2025.2
Is it something incompatible with Py3.13 ? What I need to do to fix it?
BR
Python mistakes in plugins
- Domoticz version: 2025.1
Re: Python mistakes in plugins
This is the only error you get from this? No more hints in the log?
Python 3.13 is supported.
svd71
Thank you for you message!
It's going from Domoticz-log.
This post(viewtopic.php?p=327194#p327194) shows little bit others:
Python3.13 does not work, but Python3.12 works fine.
I did it yesterday with installation of Python3.12 under pyenv.
BR.
BR.
How do you do that, running a lower version of Python in Domoticz?
