Using P1-device form Dutch Homewizard
Domoticz version: 2026.3
Re: Using P1-device form Dutch Homewizard
Seems the eraser3 plugin has an issue after some firmware update in the home wizard. Gettevan forked the plugin and fixed it:
https://github.com/gettevan/HomeWizard-Wifi-p1-plugin
fdemees
Domoticz version: 2024.7
Post by fdemees »
waltervl wrote: Saturday 29 November 2025 23:42 Seems the eraser3 plugin has an issue ...
Thank you ! The fork from Gettevan works just right ! my problem is solved !
I am a bit puzzled about the multiplication by 10 when the data is imported from the JSON in float() instead of int()...
Domoticz on Rpi 3B+, ZigbeeforDomoticz, Sonoff Zigbee coordinator, several Sonoff/ESPEasy/Tasmota, IPX800, several Zigbee things, Ksenia Lares, HomeWizard batteries
jvdz
Domoticz version: 4.107
Post by jvdz »
You mean the *1000 and then Int()?
Domoticz want the values in Wh:
Electricity P1 smart meter
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=USAGE1;USAGE2;RETURN1;RETURN2;CONS;PROD
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
USAGE1= integer, total cumulative energy usage meter tariff 1 in Wh.
USAGE2= integer, total cumulative energy usage meter tariff 2 in Wh.
RETURN1= integer, total cumulative energy return meter tariff 1 in Wh.
RETURN2= integer, total cumulative energy return meter tariff 2 in Wh.
CONS= actual usage power (Watt)
PROD= actual return power (Watt)
USAGE and RETURN are total cumulative counters (they should only count up).
For USAGE and RETURN supply the data in total Wh with no decimal point.
(So if your meter displays f.i. USAGE1= 523,66 KWh you need to send 523660)
Domoticz will calculate the today values based on the delta's in the total cumulative energy of today.
fdemees
Post by fdemees »
jvdz wrote: Sunday 30 November 2025 11:23 You mean the *1000
The telegram shows:
1-0:1.7.0(00.387*kW)
The JSON shows
"active_power_w":387.000
Thanks to the firmware in the HoweWizard dongle, the conversion occurs there.
rini52
Domoticz version: 2025.2
Post by rini52 »
this is what I used:
https://github.com/etmmvdp/HomeWizard-B ... /tree/main
and never had a problem. You create some sensors and of you go.
Added some summary scripts and never had a problem
Regards Rini
see:
viewtopic.php?t=43321
Screenshot from 2025-12-01 17-28-55.png (51.6 KiB) Viewed 3888 times
Domoticz running on Pi-4, Ubuntu(amd64), Synology Nas and VM
Hardware: RFXCOM, RFLINK, P1-smartmeter-HomeWizard, Z2M Sonoff dongle(20+ devices), Esp8266 (counters), Eaton_3S ups
rini52 wrote: Monday 01 December 2025 14:39 this is what I used:
Regards Rini
see:
This is the Homewizard Battery plugin , not the P1 device plugin.
rini52
Post by rini52 »
apologies :o
candrian
Domoticz version: 2026.2
Post by candrian »
I am using a python script to connect the P1 dongle to the native domoticz P1 driver (with LAN interface):
It's basically a server waiting for connection from domoticz. When connected, it polls the dongle and pushes telegrams to the domoticz P1 driver.
The poll period should be shorter (here: 5s) than the P1 update rate defined in domoticz (mine: 10s)
#!/usr/bin/python
import socket
import urllib.request
import time
p1ip = "192.168.1.99"   # Address of P1 dongle - assigned in DHCP server (router)
domoPort = 9595   # The port defined in Domoticz P1 configuration
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(("localhost", domoPort))
s.listen()
while True:
    c, a  = s.accept()
    print("Connected to " + str(a))
    while True:
        time.sleep(5)   # Poll period
        try:
            tg = urllib.request.urlopen("http://" + p1ip + "/api/v1/telegram").read()
            #print(tg)
            try:
                c.send(tg)
            except:
                break   # Probably lost connection, go back to listening
        except:
            pass   # P1 dongle not responding, just keep trying
    print("Connection lost")
    try:
        c.close()
    except:
        pass
It's running outside domoticz, so I use a bash script to start/stop together with domoticz:
#!/usr/bin/bash
case $1 in
start)
    kill "$(cat /tmp/p1hw.pid 2>/dev/null)" 2>/dev/null
    python3 /home/pi/p1hw_server/p1hw.py >/dev/null 2>&1 &
    echo $! > /tmp/p1hw.pid
stop)
    rm /tmp/p1hw.pid 2>/dev/null
esac
Have fun!
Calin
I think using the python plugin would be the easiest option as Domoticz will do the communication for you. No need to worry about keeping another service up and manipulate a Domoticz hardware gateway.
jvdz
Post by jvdz »
candrian wrote: Thursday 01 January 2026 17:52 The poll period should be shorter (here: 5s) than the P1 update rate defined in domoticz (mine: 10s)
Didn't simply changing that setting to 5 seconds instead of 10 work for you?
candrian
Post by candrian »
waltervl wrote: Thursday 01 January 2026 23:09 I think using the python plugin would be the easiest option as Domoticz will do the communication for you. No need to worry about keeping another service up and manipulate a Domoticz hardware gateway.
I was transitioning from wired P1 to WIFI P1, so I didn't want a new plugin creating another set of devices and risk losing the history.
I did try (a bit) to do the same (what I do outside) inside a plugin, but it would need multithreading inside the plugin and it's too cumbersome.
What is needed in fact is a version of the built-in P1 with LAN that is able to send a HTTP GET every x seconds, not just wait for telegrams to come by themselves. Maybe I'll start looking in the C sources.
jvdz wrote: Friday 02 January 2026 9:56 Didn't simply changing that setting to 5 seconds instead of 10 work for you?
My solution has successive sampling points, all adding to the latency:
- The meter itself samples every 1s and sends a telegram.
- The WIFI dongle gets all telegrams, but only sends the last one when asked.
- My "service" polls every 5s - it will get a telegram maybe 1s old and will push it to Domoticz.
- Domoticz samples every 10s, meaning it skips telegrams until the sampling point. When it will choose one, it can be 5s old from my service.
Conclusion: For a wired P1 Domoticz can be off by 1s, for my new solution it can be off by 6s.
Yeah, many choices are possible, depending on what you expect from the system. I was always targeting 10s cycle time in Domoticz and I can live with 6s latency.
But clearly the service poll time should be <= domoticz poll time, otherwise domoticz will use several times the same telegram.
jvdz
Post by jvdz »
but the plugin does have a parameter you can change in the code:
    #Plugin variables
    pluginInterval = 10     #in seconds
    dataInterval = 60       #in seconds
    dataIntervalCount = 0
    use_p1_device = False
and when you use the "P1-WiFi-Gateway" hardware, you can change the frequency in the hardware setup page.
candrian
Post by candrian »
jvdz wrote: Friday 02 January 2026 11:55 but the plugin does have a parameter you can change in the code:
    #Plugin variables
You're right! It seems to have a mode to feed data in the P1 device(s) (or some other device, I'm not sure).
There are several HoWiz P1 plugins floating around, I didn't look closely to the one called "battery something"... The others don't have that.
However (!) it only transfers power data - not gas and water. (From browsing plugin.py, I wish things were better documented)
Coming back to your remarks, the frequency is not the issue here - all solutions can adjust it. My goal was to pass the original telegram to the built-in P1 driver, to allow full decoding and mapping to devices, including gas and water.
