Hi all.
I have old Paspberry pi 3B with 1G on the board, Bullseye, and Domoticz Version: 2024.7.
I did installed couple of plugins: SamsungTV, Mikrotik, RPi, tasmota-auto.
But I have problem with my own plugin. I had checked all:
permissions, owner, start in console with python (run without errors).
After restart of domoticz-service does not see any information in the log about plugins-initialization process.
I have did a mistake in the plugins code and restart the service again - no error messages.
can somebody explain me what I did wrong?
BR.
include my own pythons plugin in the domoticz
- Domoticz version: 2025.1
Re: include my own pythons plugin in the domoticz
Did you add it as a hardware gateway?
- madpatrick
- Domoticz version: 2025.2
Can you share the plugin then we can test if it works with others systems
svd71
@madpatrick : The plugin is hier in spoiler:
- Spoiler: show
That is in menu Setup-Hardwaresvd71 wrote: Monday 29 December 2025 12:41 @walterw: what is it a "hardware gateway" and how need to add to the domoticz? Send please me a link to description of process if it present.
See wiki for installing a plugin https://wiki.domoticz.com/Using_Python_ ... g_a_plugin
By the way, there is already a MQTT Tasmoticz plugin available:
viewtopic.php?t=21918
svd71
thank you very much!
I have it. But it is same question, why I did not see it in the menu "Hardware" for settings.
- image_2025-12-29_132036243.png (91.26 KiB) Viewed 41 times
- image_2025-12-29_131901691.png (38.61 KiB) Viewed 41 times
- image_2025-12-29_131834765.png (11.79 KiB) Viewed 41 times
You first have to add it in the form below this list: https://wiki.domoticz.com/Hardware_Setu ... re_Gateway
svd71
Thank you very much!
I had found it !!!
I had found it !!!
- image_2025-12-29_135404741.png (35.11 KiB) Viewed 36 times
