i've wireguard server for my lan, and I can access to my lan from remote, I can reach zigbee server, portainer server, node red server, etc
but not my domoticz server
domoticz is into a container
it's the only server I can't reach.
i suppose that is something related to domoticz container, but I cant find a way to resolve it
I attach domoticz and wg-easy stacks compose.
Domoticz info
Version: 2025.2 (build 16818)
Build Hash: 2f9016a8b
Compile Date: 2025-10-19 11:41:46
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
Active User: pi
Thanx for any suggestion and help
Fabrizio
domoticz stack
version: '3.8'
services:
domoticz:
image: domoticz/domoticz:stable
container_name: domoticz
restart: unless-stopped
depends_on:
- mosquitto
networks:
myNetwork:
ipv4_address: ---.---.---.153
ports:
- "8080:8080"
volumes:
- /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/domoticz:/opt/domoticz/userdata
mosquitto:
image: eclipse-mosquitto
container_name: mosquitto
restart: always
volumes:
- /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/mqtt/config:/mosquitto/config
- /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/mqtt/data:/mosquitto/data
- /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/mqtt/log:/mosquitto/log
networks:
myNetwork:
ipv4_address: ---.---.---,160
ports:
- 1883:1883
- 9001:9001
stdin_open: true
tty: true
homebridge:
image: homebridge/homebridge:ubuntu
container_name: homebridge-dz
restart: always
depends_on:
- domoticz
# network_mode: host
networks:
myNetwork:
ipv4_address: ---.---.---.142 #add ip here
ports:
- "1968:1968"
environment:
- HOMEBRIDGE_CONFIG_UI_PORT=1968
volumes:
- /srv/dev-disk-by-uuid-83b6a8f9-5b92-4b9f-ab73-81c3cf7cc424/homebridge:/homebridge
networks:
myNetwork:
external: true
wg-easy
volumes:
etc_wireguard:
services:
wg-easy:
environment:
# Change Language:
# (Supports: en, ua, ru, tr, no, pl, fr, de, ca, es, ko, vi, nl, is, pt, chs, cht, it, th, hi)
- LANG=it
# ⚠️ Required:
# Change this to your host's public address
- WG_HOST=---.---.----.168
# Optional:
- PASSWORD_HASH=$-------------------------------------------------------------------------------------------------- see "How_to_generate_an_bcrypt_hash.md" for generate the hash)
- PORT=51821
- WG_PORT=51821
# - WG_CONFIG_PORT=92820
# - WG_DEFAULT_ADDRESS=10.8.0.x
# - WG_DEFAULT_DNS=1.1.1.1
# - WG_MTU=1420
- WG_ALLOWED_IPS=---.---.---.0/24
# - WG_PERSISTENT_KEEPALIVE=25
# - WG_PRE_UP=echo "Pre Up" > /etc/wireguard/pre-up.txt
# - WG_POST_UP=echo "Post Up" > /etc/wireguard/post-up.txt
# - WG_PRE_DOWN=echo "Pre Down" > /etc/wireguard/pre-down.txt
# - WG_POST_DOWN=echo "Post Down" > /etc/wireguard/post-down.txt
# - UI_TRAFFIC_STATS=true
# - UI_CHART_TYPE=0 # (0 Charts disabled, 1 # Line chart, 2 # Area chart, 3 # Bar chart)
# - UI_SHOW_LINKS=true
# - UI_ENABLE_SORT_CLIENTS=true
image: ghcr.io/wg-easy/wg-easy
container_name: wg-easy
volumes:
- etc_wireguard:/etc/wireguard
ports:
- "51821:51821/udp"
- "51821:51821/tcp"
cap_add:
- NET_ADMIN
- SYS_MODULE
# - NET_RAW # ⚠️ Uncomment if using Podman
sysctls:
- net.ipv4.ip_forward=1
- net.ipv4.conf.all.src_valid_mark=1
