New smart watermeters in NL in 2026 BrabantWater issue Topic is solved
zicht
- Domoticz version: 2023.1+
[edit : please read below post (01-01-2026) where i descibe the problem better ]
Did someone allready investigated the new smart watermeters that are rolled out in 2026 in the Netherlands ? There is some small talk going around that is will become obligated soon.
Is there anything on this watermeter we can stiil detect with a sensor ? There is no api or interface available (yet?) --> so to keep functionality i need to replace my PNP type detector with something else i suppose.
Why ? If someone is in the shower a light blinks every 50 liter or 5 min of water consumption and gets more red as the value gets higher, i would like to find a way to keep this functionality, I also count the amount of warmwater, gardenwater we use.
Thanks for sharing info and ideas so we can get prepaired for the change
- Domoticz version: 2026.3
Re: New smart watermeters in NL in 2026
I believe it is already implemented when using the DSMR P1 smart meter integration. There are already people having a watermeter connected to their P1 smart meter.
zicht
would be nice that way.... Hope it will be the standard for all watersupplierswaltervl wrote: Sunday 21 December 2025 14:49 I believe it is already implemented when using the DSMR P1 smart meter integration. There are already people having a watermeter connected to their P1 smart meter.
I suppose so. Watermeter connected to P1 Smart meter is in Domoticz supported from version 2022.2 https://wiki.domoticz.com/Dutch_DSMR_sm ... n_Domoticz
zicht
Updated: New smart watermeters in NL in 2026 (BrabantWater does not use p1)
Hi Walter & All
First of all the best wished for 2026 ! Thanks for this great platform ...
The problem is BrabantWater. They dont use smartmeter integration, in stead they launch their own platform Waterbewust without api and with a fee of 120 euro a year !! Absurt : they turn this into a money maker.
I have currently my PNP sensor device widely integrated in my home for detecting waterusage (coldwater, warmwater + Gassusage for warmwater, gardenwater Usage, leakage detection, blinking lights & colors during showering based on waterusage etc) By the insight of this i reduced waterusage a lot and even detected a faulty washer watervalve malfunction (small internal leakage)
So i am looking for some kind of a broker device that is capable of reading something of their device.
see https://www.brabantwater.nl/slimmewatermeter for the model used.
I think to see the device has a led that pules, but since i have no way to check i am wondering if someone has one of these devices or even better has one and managed to read it into domoticz.
best regards, and thanks for reading and working together...
- gizmocuz
Re: New smart watermeters in NL in 2026 BrabantWater issue
That is crazy! That might be half of the price you pay for all your water in a year.
So forget this, and use a proximity sensor with an ESP32, that is how I track my water until there is one installed that works with the P1 meter
You can have a look at my attempt here
https://github.com/gizmocuz/esp_proximity_sensor_mqtt
zicht
Thanks ! And indeed crazy...gizmocuz wrote: Friday 02 January 2026 7:41
I looked at your github, i have something similar detecting on my current analog watermeter on the metal running arround when using water ( homebrew)
I dont believe a poximity sensor will work at the new digital meter they use. Maybe it has a blinking led on usage that we can use like the early days of digital electricity meters ? maybe I can replace my current sensor with an ldr
On the Kamstrup IQ there is an IR signal that can be read, see the following discussion:
https://community.home-assistant.io/t/k ... /403109/16
The Sagemcom Siconia also seems to have an IR interface. Data (like the Kamstrup FlowIQ) seems to be transmitted to the water company by Lora (hopefully and probably encrypted).
https://device.report/manual/3121527
zicht
waltervl wrote: Saturday 03 January 2026 16:10 On the Kamstrup IQ there is an IR signal that can be read, see the following discussion:
from that threat :
"as this is somewhat throttled by the meter firmware to limit battery usage. Perhaps I’m just lucky or perhaps the newer meter versions doesn’t have this previous fw restriction ?
So far I’ve done some 800+ reads last 48 hours and I’m still reading registers without issues every 5 minutes. I’m using the cenobitedk ESPHome component as base to read the meter. Using same component with identical hardware to read my district heating Multical 602 meter as well."
it confirms what i suspected, it has an IR signal but is very limited compaired to current situation with my homebrew sensor.
The firmware of the kamstup has probably a battery saver so we get data very late.
Its a pitty this kind of vendors & watersuppliers dont think about homeautomation ... its al about the money.
lets be patient and see how things develop over time... maybe there will be something more exposed or firmware adjustements that helps us getting more values ....
i also found that the current elster meter is still available -> for the price of one year waterbewust platform i can buy a brand new one and place it in serie with the new watermeter. Could also be a solution
Or ask the engineer that is going to replace the meter to leave the current one in place and have the new one mounted before the old one (if there is space).
I also don't understand why they not lift along with the existing smart electricity and gas meter infrastructure.
The Kamstrup can be read by smartgateways Kamst-IR Gateway https://smartgateways.nl/maak-je-kamstr ... eter-slim/ into Domoticz https://haprofs.com/kamstrup-multical-s ... -domoticz/waltervl wrote: Saturday 03 January 2026 16:10 On the Kamstrup IQ there is an IR signal that can be read, see the following discussion:
- gizmocuz
If it has a blinking LED... maybe you can use a YouLess
https://www.youless.nl/hoewerkt.html
But a simple ESP with LED detection might also work
zicht
Thanks, i will keep you posted when relevant of the solution that works for me and open a new post with link to this one.
For now i try to delay the install as long as reasonable possible.
Marked this as solved for now.
i really appriciate thinking with me towards solutions, many thanks for that !
The Kamstrup FlowIQ 2200 from Brabantwater is not yet enabled for local reading:
See this (Dutch) discussion: https://gathering.tweakers.net/forum/li ... es/2320792
