Yes. You're right.I have all of this. I need the device or script to calculate the device's power in watts x time, i.e., the amount of thermal energy in kWh.BartSr wrote: Sunday 21 December 2025 16:40 For yr calculation you need:
Measure device for E-input
Temp measure device inlet water
Temp measure device outlet water
Waterflow measure device.
All available?
Domoticz thermal energy kWh, thermal energy meter Topic is solved
geoterm
Re: Domoticz thermal energy kWh, thermal energy meter
geoterm
Computed or from device ?
- Przechwytywanie.JPG (41.69 KiB) Viewed 3989 times
geoterm
In my opinion, this device is not working. It shows the current power in watts, but does not calculate energy in kWh. There is no data in the logs.
- 1.JPG (10.3 KiB) Viewed 3986 times
- 2.JPG (60.35 KiB) Viewed 3986 times
- Domoticz version: 2026.3
It should be set to calculated (as you do not supply the kwh counter) and you have to supply the watt data in Watts, not kW.
geoterm
It works
. Thank you.
And actually providing the device with a value in Watts.
The key was writing the dz vents script:
devices = {
200
domoticz.devices(277).updateElectricity(domoticz.utils.round((domoticz.devices(252).temperature * domoticz.devices(200).flow *63.65), 0))
}- Attachments
- a3.JPG (58.38 KiB) Viewed 3974 times
- a1.JPG (25.9 KiB) Viewed 3974 times
- a2.JPG (47.55 KiB) Viewed 3974 times
geoterm
How to create a device that calculates only today Wh or total Wh ?
- b2.JPG (43.59 KiB) Viewed 3961 times
- b1.JPG (27.34 KiB) Viewed 3961 times
BartSr
- Domoticz version: V2024.7
This device automaticly resets the daily usage to 0 at 00.00h
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
geoterm
Ok, but I want to display today wh and total wh on the display. How to do it?
You cannot do that, there is no option for that. The whtotal value is only available on the log-report page of the device.
geoterm
Okay, that's what I felt.
geoterm
I have a new challenge. In a new post. It concerns electricity, or rather, energy balance.
geoterm
I've noticed an error in the temperature delta between the supply and return. On the left is the value calculated by the ESP32, and on the right by the Domoticz script. Domoticz is calculating the delta incorrectly. Why?
When I restart the raspberry it counts fine for some time.
https://www.youtube.com/watch?v=zELH0_coS5U
geoterm
I had a problem removing devices—Domoticz was freezing. I temporarily disabled all LUA scripts, and now I can delete unnecessary devices.
- RonkA
- Domoticz version: 2025.1
Hi, I see in the video the initial values are not the same, that seems to me that the temperatures are not calibrated right.
Also the sample times to do the calculations is not in sync so this will introduce further deviation..
What i am stating here are pure guesses from my part because, besides this video without audio or description, you don't give a lot of information..
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
What is your script, and how is it triggered, on device change of one of the 2 temperature devices?
And better post this question in a Lua specific topic as it is not related to energy device. viewforum.php?f=61
geoterm
I think I managed to solve this problem with the help of Google. I also had trouble removing unnecessary devices—Domoticz was freezing. I disabled LUA scripts, removed the unnecessary devices, re-enabled LUA scripts, and observed that Domoticz was counting correctly. Thanks for the tips.
geoterm
It is possible that I had temperature sensors with duplicate names, e.g. "tz" and "tZ".
