can i use .after(900) with selector switch  [Solved]
Gravityz
Domoticz version: 2026.3
Post by Gravityz »
i am using this function normally on regular switches.
does the .after(900) also work on selector switches
i want to switch to a certain level and switch back to the previous level after 900 seconds
Ventilatie Mode is a text device
Control Mode is a selector switch with levels 0, 10 and 20
0 is default level
    if (device.name =='Ventilatie Mode' and device.text == 'Stand 3') then
        domoticz.devices('Control Mode').switchSelector(10)
        domoticz.devices('Control Mode').switchSelector(0).after(900)
TiXav
Re: can i use .after(900) with selector switch  [Solved]
Post by TiXav »
yes but afterSOMETIME like afterHour(hours), afterMin(minutes), afterSec(seconds) see https://wiki.domoticz.com/DzVents:_next ... _scripting
I use it often
dz.devices("Terrasse_RGBW").switchSelector('BlancFort').checkFirst()
dz.devices('Terrasse_RGBW').switchSelector('Off').afterSec(600)
dz.devices("Bornes_RGBW").switchSelector('BlancFort').checkFirst()
dz.devices('Bornes_RGBW').switchSelector('Off').afterSec(600)
