Hi, can anyone tell me what this crash log means? Is it a faulty plugin?
I get this when restarting Domoticz. Domoticz works fine though, but sometimes after an update (Beta) it does not start. This is the crash log:
gdb: warning: Couldn't determine a path for the index cache directory.
[New LWP 6224]
[New LWP 6223]
[New LWP 6222]
[New LWP 6221]
[New LWP 6220]
[New LWP 6219]
[New LWP 6218]
[New LWP 6217]
[New LWP 3195]
[New LWP 3193]
[New LWP 3192]
[New LWP 3191]
[New LWP 3181]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
Id Target Id Frame
* 1 Thread 0x7f9d1e4de0 (LWP 3179) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2 Thread 0x7f85fbef20 (LWP 6224) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
3 Thread 0x7f867cef20 (LWP 6223) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
4 Thread 0x7f87ffef20 (LWP 6222) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
5 Thread 0x7f989f0f20 (LWP 6221) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
6 Thread 0x7f981e0f20 (LWP 6220) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
7 Thread 0x7f979d0f20 (LWP 6219) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
8 Thread 0x7f86fdef20 (LWP 6218) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
9 Thread 0x7f971c0f20 (LWP 6217) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
10 Thread 0x7f877eef20 (LWP 3195) "Watchdog" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
11 Thread 0x7f94970f20 (LWP 3193) "MainWorker" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
12 Thread 0x7f95180f20 (LWP 3192) "domoticz" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
13 Thread 0x7f95990f20 (LWP 3191) "mDnsWorker" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
14 Thread 0x7f9af7ef20 (LWP 3181) "SQLHelper" 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
Thread 14 (Thread 0x7f9af7ef20 (LWP 3181) "SQLHelper"):
#0 0x0000007f9c71efa8 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#1 0x0000007f9c712658 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#2 0x0000007f9c71269c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#3 0x0000007f9c77b3e0 in select () from /lib/aarch64-linux-gnu/libc.so.6
#4 0x0000005595587660 in StoppableTask::IsStopRequested(int) ()
#5 0x000000559555742c in CSQLHelper::Do_Work() ()
#6 0x0000005595c9ea8c in execute_native_thread_routine ()
#7 0x0000007f9c715f78 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#8 0x0000007f9c77de8c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
Thread 13 (Thread 0x7f95990f20 (LWP 3191) "mDnsWorker"):
#4 0x000000559563bd90 in domoticz_mdns::mDNS::mDnsMainLoop() ()
#5 0x0000005595c9ea8c in execute_native_thread_routine ()
#6 0x0000007f9c715f78 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#7 0x0000007f9c77de8c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
Thread 12 (Thread 0x7f95180f20 (LWP 3192) "domoticz"):
#5 0x00000055954ca1a8 in CKWHStats::PeriodicSaveKWHStats(int) ()
Thread 11 (Thread 0x7f94970f20 (LWP 3193) "MainWorker"):
#5 0x000000559550a5a0 in MainWorker::Do_Work() ()
Thread 10 (Thread 0x7f877eef20 (LWP 3195) "Watchdog"):
#2 0x0000007f9c74e29c in clock_nanosleep () from /lib/aarch64-linux-gnu/libc.so.6
#3 0x0000007f9c758880 in nanosleep () from /lib/aarch64-linux-gnu/libc.so.6
#4 0x00000055954ad544 in sleep_milliseconds(long) ()
#5 0x000000559553ca00 in Do_Watchdog_Work() ()
Thread 9 (Thread 0x7f971c0f20 (LWP 6217) "domoticz"):
#2 0x0000007f9c7129f0 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#3 0x0000007f9c7153ec in pthread_cond_wait () from /lib/aarch64-linux-gnu/libc.so.6
#4 0x00000055956ab0f8 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::sco
#5 0x0000005595a4fd7c in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
#6 0x0000005595a5541c in boost::asio::detail::posix_thread::func<boost::asio::system_context::thread_function>::run() ()
#7 0x00000055956a5c3c in boost_asio_detail_posix_thread_function ()
#8 0x0000007f9c715f78 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#9 0x0000007f9c77de8c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
Thread 8 (Thread 0x7f86fdef20 (LWP 6218) "domoticz"):
Thread 7 (Thread 0x7f979d0f20 (LWP 6219) "domoticz"):
Thread 6 (Thread 0x7f981e0f20 (LWP 6220) "domoticz"):
Thread 5 (Thread 0x7f989f0f20 (LWP 6221) "domoticz"):
Thread 4 (Thread 0x7f87ffef20 (LWP 6222) "domoticz"):
Thread 3 (Thread 0x7f867cef20 (LWP 6223) "domoticz"):
Thread 2 (Thread 0x7f85fbef20 (LWP 6224) "domoticz"):
Thread 1 (Thread 0x7f9d1e4de0 (LWP 3179) "domoticz"):
#3 0x0000007f9c76aa24 in wait4 () from /lib/aarch64-linux-gnu/libc.so.6
#4 0x000000559553c2a4 in dumpstack_gdb(bool) ()
#5 0x000000559553c814 in signal_handler(int, siginfo_t*, void*) ()
#6 <signal handler called>
#7 0x0000007f9c717dc0 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
#8 0x0000007f9c6c6980 in raise () from /lib/aarch64-linux-gnu/libc.so.6
#9 0x0000007f9c6b1ac4 in abort () from /lib/aarch64-linux-gnu/libc.so.6
#10 0x0000007f9b26da78 in ?? () from /lib/aarch64-linux-gnu/libpython3.13.so
#11 0x0000007f9b26dafc in _Py_FatalErrorFunc () from /lib/aarch64-linux-gnu/libpython3.13.so
#12 0x0000007f9b245204 in PyEval_RestoreThread () from /lib/aarch64-linux-gnu/libpython3.13.so
#13 0x00000055959d1a84 in Plugins::CPluginSystem::StopPluginSystem() ()
#14 0x00000055955043a4 in MainWorker::Stop() ()
#15 0x000000559541368c in main ()
Main thread:
[Inferior 1 (process 3179) detached]
crash log question
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2026.3
Re: crash log question
Latest 2 or 3 beta updates fail when updating through web gui. Gizmocuz is working on the update script.
See also viewtopic.php?t=44190
Andreotti
- Domoticz version: latest
The latest: Version: 2025.2 (build 16997)
But this appeared earlier also.
I get this log also when I restart Domoticz.
